IP configuration issue on 800 series
OPSYS2011
Hi all,
I have two locations connected by a ISDN line and two Cisco 803.
One week ago I had to replace a failed Cisco 803 with a new 876W.
My experience is obsolete when not vanished so I'm in a big trouble trying to restart the link.
After many changes I've been able to get  connection and autentication between the 876 and the old 803 but now I get an error I can't solve.
The HPN (876) dial the BFR (803) where I get this (debug dialer on the receiving side):
complete listing of debug is:
5d17h: BR0:2 PPP: Phase is AUTHENTICATING, by both
5d17h: BR0:2 CHAP: O CHALLENGE id 135 len 30 from "BFR"
5d17h: BR0:2 CHAP: I CHALLENGE id 10 len 30 from "HPN"
5d17h: BR0:2 CHAP: Waiting for peer to authenticate first
5d17h: BR0:2 CHAP: I RESPONSE id 135 len 30 from "HPN"
5d17h: BR0:2 CHAP: O SUCCESS id 135 len 4
5d17h: BR0:2 CHAP: Processing saved Challenge, id 10
5d17h: BRI0:2 DDR: Authenticated host HPN with no matching dialer map
5d17h: BR0:2 CHAP: O RESPONSE id 10 len 30 from "BFR"
5d17h: BR0:2 CHAP: I SUCCESS id 10 len 4
5d17h: BR0:2 PPP: Phase is UP
5d17h: BR0:2 IPCP: O CONFREQ [Closed] id 8 len 10
5d17h: BR0:2 IPCP:    Address 192.168.11.133 (0x0306C0A80B85)
5d17h: BR0:2 IPCP: I CONFREQ [REQsent] id 1 len 10
5d17h: BR0:2 IPCP:    Address 0.0.0.0 (0x030600000000)
5d17h: BR0:2 IPCP: Cannot satisfy pool request
5d17h: BR0:2 IPCP: Neither side knows remote address
5d17h: BR0:2 IPCP: O CONFREJ [REQsent] id 1 len 10
5d17h: BR0:2 CDPCP: I CONFREQ [Not negotiated] id 1 len 4
5d17h: BR0:2 LCP: O PROTREJ [Open] id 87 len 10 protocol CDPCP (0x820701010004)
5d17h: BR0:2 IPCP: I CONFACK [REQsent] id 8 len 10
5d17h: BR0:2 IPCP: I CONFREQ [ACKrcvd] id 2 len 4
5d17h: BR0:2 IPCP: O CONFACK [ACKrcvd] id 2 len 4
5d17h: BR0:2 IPCP: State is Open
5d17h: BRI0:2 DDR: dialer protocol up
The connection is estabilished but the ping fails.
I think this is due to the IP configuration on the new router but can't find a solution.
May be the Vlan or BVI interface are wrong?
Where coul'd I find a minimal configuration for connecting two 876 via ISDN?
Thank you so much in advance.
Joseph.C
This is the configuration of the 876 that I'm working on.
version 12.4
no service pad
service password-encryption
hostname HPN
enable secret 5 $XXXXX
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
isdn switch-type basic-net3
username admin privilege 15 secret 5 $xxxx
username BFR password 7 04xxxxx
archive
log config
  hidekeys
bridge irb
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
isdn point-to-point-setup
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface Dialer0
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer remote-name BFR
dialer string 06977
dialer-group 1
ppp authentication chap
interface BVI1
ip address 167.228.169.113 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 167.228.169.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
Put some private IP address on Dialer, preferable /30 subnet
and also add route accordingly for the same.
Smitesh
