Routing issue ASA5510 and CCME
Hello community.
I have issues with ccme voice vlan, it is invisible(i cant ping 192.168.2.1) from root ASA.
So i have 192.168.0.1 as data vlan (1) and 192.168.2.1 as voice vlan , voice vlan used on root switch and connected to ASA but voice vlan invisible from asa5510.
on ccme it looks like:
interface GigabitEthernet0/2.1
 encapsulation dot1Q 1
 ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/2.2
 description Voice
 encapsulation dot1Q 2
 ip address 192.168.2.1 255.255.255.0
everything else working  fine.
Thanks for posting back to the forum to let us know that you have solved the issue and how you fixed it.
Rick
Rick
Richard Burts
There is not enough information here for us to be able to identify the problem. At minimum you need to post the relevant parts of the ASA config and to provide information about the connection between ccme and ASA.
Rick
Rick
Thank you, everything it fine, it is solved just adding another one routing rule to ASA config.
Rick
Rick
