Routing Issue cisco 3750 Version 12.2(55)SE5
malloy184
We have a 3750 stack with the default route connected to the MPLS of the customer. We have to move a connexion to a partner from the MPLS to a new VPN. I just add a static route of the IP address of the partner to the firewall VPN. then the VPN is setup and is OK. When I try to ping the ip of the partner through the new static route I don't see the packets in the firewall. Firewall is a ASA in the LAN of the 3750.
To resume when I change this:
ip route 0.0.0.0 0.0.0.0 x.x.x.x (x.x.x.x is MPLS router)
to
ip route 1.2.3.3 255.255.255.255 y.y.y.y (y.y.y.y is Firewall VPN)
I don't see icmp packet arrived on my firewall
Do you have any idea why it don't work?
If you need more details i'll provide them.
Thank you  !!
0 Replies 0
