REP and STP interoperability
gnijs
Level 4
Level 4
I have read the REP white paper, but i have still no answer if the following topologies are supported:
* Multiple REP segments inside a single ring, merged together with RapidSTP:
    SW1 --- REP Seg 1 -- SW2 -- REP Seg 1 -- SW3 --- Rapid STP --- SW4 --- REP Seg 1 --- SW5 -- REP Seg 1 -- SW6 -- Rapid STP -- SW7 -- REP Seg 1 -- back to SW1
* If supported, can the segment ID in such a scenario be the same or must if be different:
    SW1 --- REP Seg 1 -- SW2 -- REP Seg 1 -- SW3 --- Rapid STP --- SW4 --- REP Seg 2 --- SW5 -- REP Seg 2 -- SW6 -- Rapid STP -- SW7 -- REP Seg 1 -- back to SW1
regards,
Geert
0 Replies 0
