routing issue- seeing same IPs for two hops
Hello All,
I'm seeing two same IPs in the traceroute output. Is that due to routing issue that nexhop is as the same device for the first time?
Log:
10.30.102.26  61.060 ms 10.30.100.142  61.266 ms 10.30.102.26  61.071 ms
10.30.102.26  61.139 ms  61.211 ms 10.61.191.2  60.948 ms
Can you  guys help me to fix the issue??
Thiyagu
devils_advocate
Level 11
Level 11
What is that device?
Can you check and post its config on here?
John Blakley
Are you load balancing anywhere?
6 10.30.102.26  61.060 ms
7 10.30.102.26  61.139 ms  61.211 ms
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
