Routing issues for WLC to APs
stacey.hummer
Good day all,
I'm trying to resolve an issue I'm having with connecting a WLC to the access points. I've inherated a netgear WLC and access points. Having redesigned the network and moving the WLC into the datacenter I am unable to connect to the APs. The APs are on 192.168.0.x addresses and the WLC is on 10.2.0.x address. I am able to ping to the closest switch (the one the APs are actually attached to) but not the the APs themselves.
All other devices are Cisco devices 4006 to 2950. So it goes WLC (10.2.0.33) - 4006 (10.2.0.23, 192.168.0.99) - 2950 (192.168.0.100) - APs (192.168.0.10 - 35)
I have OSPF enabled, I am able to ping from the WLC to the 2950. So from 10.2.0.33 to 192.168.0.100, no problem with that. I try and  ping from 10.2.0.33 to any of the APs ie 192.168.0.15 and it cannot find it.
Any suggestions would be greatly appreciated
Stacey
ALIAOF_
Level 6
Level 6
Can you provide a network diagram is there a firewall in between WLC and AP's?  I did not even know Netgear made WLC's.
