Routing L2L
damianpablo
Hello, i have next one trouble.
I have one L2L; my router1 no reach my Host1 using ping. My stage iis the next one. but i reach interface lan router2 10.10.1.1
Router 1.
Config:
Interface FastEthernet 0/0
Description L2L
ip address: 1.1.1.2  255.255.255.0
Interface FastEthernet 0/1
Description Lan
192.168.1.1 255.255.255.0
Ip route 0.0.0.0 0.0.0.0 1.1.1.3
Router 2
Description L2L
ip address: 1.1.1.3  255.255.255.0
Description Lan
10.10.1.1 255.255.192.0
Ip route 0.0.0.0 0.0.0.0 10.10.1.20
Host1 Connect physical to Router 2.
Host 1 Ip Address:  ip address 10.10.1.20 mask 255.255.192.0 DG 10.10.1.1
my laptop it had firewall on. I shut down my firewall and everything worked good,
Thanks everybody
5 Replies 5
Deepak Kumar
You have wrong configured routing on R2 as
As you mentioned that 10.10.1.20 is host IP. So this route is not required.
Please modify a default route on R2 as
Ip route 0.0.0.0 0.0.0.0 1.1.1.2
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
thanks Deepak kumar
i resolve my trouble whit shutdown windows firewall on my host1
Thanks everybody
Thanks for posting and letting us know that the problems seems to be the firewall on your laptop.
Rick
Rick
your wellcome richard
