Routing on a Cat 9300
GianniB
I have a this switch and I'm trying to setup a very simple routing command to send all traffic to the next hop.  The basic configuration I have done is:
  • IP Routing
  • IP route 0.0.0.0 192.168.11.1
  • Vlan 1 address 172.16.104.1/24
  • All switch ports on Vlan 1
  • Te1/1/1
    • No switchport
    • address: 192.168.11.104/24
From the switch I can ping 8.8.8.8 just fine
From a PC connected I can ping
  • 172.16.104.1
  • 192.168.11.104
But can't ping
  • 192.168.11.1
  • Or the internet
Running tracert from the PC I can see it reach 172.16.104.1 as the first hop but after that everything else fails.
I don't have access to the 192.168.11.1 device (corporate rules).  I do not have any routing protocols or NAT setup.  I feel like I'm missing on simple thing but not sure what it is.
John
Reza Sharifi
Since you are using a different subnet for the lan side of the switch (172.16.104.0/24), the HQ router needs to have a static route for that subnet
ip route 172.16.104.0.0 255.255.255.0 192.168.11.104
GianniB
  I don't have access to that router. I may have to change my addressing scheme
Yeah, you may have to just extend the same addressing scheme (192.168.11.0/24) to the switch, make the switch just layer-2 and make the connection to the router a switch port.
