routing on cisco 871
TomF
I am experimenting with a Cisco 871 router. The router has 4 LAN ports and 1WAN port.
What are the limitations wrt to the LAN ports when it comes to routing. Is the WAN port the only port that supports routing?
Tom
3 Accepted Solutions
Based on your image you can configure a different amount of VLANs on the 871 (up to 4 if I remember right). These can also be included into your routing-setup.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Yes, you can run routing on the VLANs in your setup.
Emmanuel Valdez
Level 3
Level 3
The Cisco 871 works with SVI because it only has one layer 3 port, so you can use routing over the SVI and not over the LAN ports because they only work for layer 2 connectivity.
If it is useful please rate.
Best regards.
5 Replies 5
Thanks for the feedback. Does this mean that I can run routing protocols like RIP on the LAN ports if I configure multiple VLANs say one per port?
I like to create a setup consisting of a Cisco 871 and a Cisco 878. The latter has no ethernet WAN port (WAN interface is a DSL interface).
I have the advanced ip software.
Tom
Emmanuel Valdez
Level 3
Level 3
Best regards.
Thanks for the help.
I managed to get the setup working.
Besides the VLAN / SVI setup I found two additional problems.
I forgot to setup the ports that connect the two routers as "trunk" ports (switchport mode trunk , switchport trunk encapsulation dot1q, etc.).
Furthermore I found that using multiple NICs in one (windows) machine leads to problems. When I try to ping the request is sent out to the wrong gateway (different gateway per NIC does not work).
Tom
