Routing OSPF through a 3750 switch
charles.e.davis
I am trying to simulate the internet by bringing in 3 different routers on point to points into a 3750G switch.  While I can ping through the network, I am not getting any convergance of OSPF.  We are using IOS version 12.2(53)se.  Thanks.
From the configurations, between Router 1, 2, and 3, there is no common subnet. While router 2 and 3 have 206.36.206.x in common, I do not see any other common subnets between all three routers. If you are configuring so that even 3750 should participate in OSPF, you need to make sure that you are running IPServices image on the switch. Once you are running IP Services image, the configuration will be pretty much similar to the routers:
Router ospf 1
Network 205.0.0.0 0.0.0.3 area 0
Network 205.1.1.0 0.0.0.3 area 0
Network 205.2.2.0 0.0.0.3 area 0
Hope this helps.
NT
5 Replies 5
Jerry Ye
Please post the config and topology so we may assist further.
jerry
The topology is 3 routers coming into the swith on P-P networks.  Each router is advertising for the network behind it as well as the P-P.
Switch Config
sho config
Using 1887 out of 524288 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750g-24ts-1u
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
ip routing
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport access vlan 10
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
switchport access vlan 20
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
switchport access vlan 30
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 205.1.1.2 255.255.255.252
interface Vlan20
ip address 205.0.0.2 255.255.255.252
interface Vlan30
ip address 205.2.2.2 255.255.255.252
ip classless
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 5 15
end
Switch#
Router 1
Using 668 out of 29688 bytes
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname Router
memory-size iomem 10
ip subnet-zero
interface Ethernet0/0
ip address 205.2.2.1 255.255.255.252
no ip directed-broadcast
interface Serial0/0
no ip address
shutdown
interface Ethernet0/1
no ip address
interface Serial0/1
no ip address
shutdown
router ospf 1
network 205.2.2.0 0.0.0.3 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 205.2.2.2
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
login
end
Router#
Router 2
Using 1016 out of 245752 bytes
version 12.4
hostname Enterprise_Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
voice-card 0
no dspfarm
archive
log config
  hidekeys
interface GigabitEthernet0/0
ip address 206.36.206.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 205.0.0.1 255.255.255.252
duplex auto
speed auto
router ospf 1
log-adjacency-changes
network 205.0.0.0 0.0.0.3 area 0
network 206.36.206.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 205.0.0.2
ip route 206.1.1.0 255.255.255.0 206.1.1.254
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Enterprise_Router#
Router 3
Using 1234 out of 245752 bytes
version 12.4
service password-encryption
hostname Base_Router
boot-start-marker
boot-end-marker
enable secret 5 $1$y5h3$INTpPIlaRy8WY1RtgLrAa0
aaa new-model
aaa authentication login default local
aaa session-id common
dot11 syslog
ip cef
voice-card 0
no dspfarm
username admin privilege 15 password 7 0257145A1815182E5E4A58
archive
log config
  hidekeys
class-map match-all CPPr-host-known-undersirable
ip address 206.36.206.3 255.255.255.0
duplex auto
speed auto
ip address 205.1.1.1 255.255.255.252
duplex auto
speed auto
router ospf 1
Router ospf 1
Hope this helps.
NT
Only one additional comment from NT's post. Once you configure OSPF on the 3750 switch and if the neighbor is not coming up, check the MTU of both side with the command ip ospf interface. From what I remember, VLAN SVI will have MTU 1504 and router interface is MTU 1500 and the neighbor will not form due to MTU mismatch. To correct this problem, you can add the following command on the router interface and the interface VLAN to bypass the MTU check
interface xxxx
ip ospf mtu-ignore
jerry
madathilsiva
Between R1 and R2 there is no proper subnet assigned . That could be reason for this . Is there any ospf running in switch?
{R1        R2
interface Ethernet0/0                                                          interface GigabitEthernet0/1
ip address 205.2.2.1 255.255.255.252                         ip address 205.0.0.1 255.255.255.252
no ip directed-broadcast                                                  duplex auto
        speed auto                        }
