routing problem across multiple routers
bradholman
I am migrating our network to a new metro-Ethernet provider, and at the same time changing our LAN subnet (because we are currently using a non-private subnet for our LAN). I have our current network on 192.47.0.0/16 using router1. I have configured a new hub router2 using 192.168.100/24, and a 'bridge' router between the two. Here is a diagram of my current configuration.
network diagram
Router1 is running RIP, Router2, Router3, and Bridge are running OSPF. My situation is that while I can ping from router1 all hops through to a client on the 192.168.11.0/24 subnet, I cannot ping from router3 to router1 (the traffic gets to the bridge router then stops).
Here is the routing table for router1:
Gateway of last resort is 192.47.100.32 to network 0.0.0.0
     192.168.72.0/32 is subnetted, 1 subnets
S       192.168.72.45 [1/0] via 192.47.100.32
S    192.47.30.0/24 [1/0] via 192.47.100.32
R    192.47.8.0/24 [120/1] via 10.1.4.254, 00:00:22, GigabitEthernet0/1.4
S    192.47.110.0/24 [1/0] via 192.47.100.32
R    192.47.9.0/24 [120/1] via 10.1.3.254, 00:00:18, GigabitEthernet0/1.3
R    192.47.10.0/24 [120/1] via 10.1.6.254, 00:00:23, GigabitEthernet0/1.6
     172.16.0.0/32 is subnetted, 1 subnets
S       172.16.209.21 [1/0] via 192.47.100.32
S    192.168.11.0/24 [1/0] via 192.47.100.9
R    192.47.11.0/24 [120/1] via 10.1.7.254, 00:00:12, GigabitEthernet0/1.7
R    192.47.4.0/24 [120/1] via 10.1.5.254, 00:00:22, GigabitEthernet0/1.5
S    192.47.21.0/24 [1/0] via 192.47.100.32
S    192.47.20.0/24 [1/0] via 192.47.100.32
R    192.47.5.0/24 [120/1] via 10.1.1.254, 00:00:03, GigabitEthernet0/1.1
R    192.47.6.0/24 [120/1] via 10.1.2.254, 00:00:17, GigabitEthernet0/1.2
     10.0.0.0/8 is variably subnetted, 9 subnets, 2 masks
C       10.1.3.0/24 is directly connected, GigabitEthernet0/1.3
C       10.1.2.0/24 is directly connected, GigabitEthernet0/1.2
C       10.1.1.0/24 is directly connected, GigabitEthernet0/1.1
C       10.1.7.0/24 is directly connected, GigabitEthernet0/1.7
C       10.1.6.0/24 is directly connected, GigabitEthernet0/1.6
C       10.1.5.0/24 is directly connected, GigabitEthernet0/1.5
C       10.1.4.0/24 is directly connected, GigabitEthernet0/1.4
S       10.1.254.168/32 [1/0] via 192.47.100.31
S       10.48.239.0/24 [1/0] via 192.47.100.32
S    192.47.1.0/24 [1/0] via 192.47.100.32
S    192.47.2.0/24 [1/0] via 192.47.100.31
C    192.47.100.0/24 is directly connected, GigabitEthernet0/0
S    192.168.100.0/24 [1/0] via 192.47.100.9
S*   0.0.0.0/0 [1/0] via 192.47.100.32
Here is the routing table for bridge:
Gateway of last resort is 192.168.100.3 to network 0.0.0.0
O    192.168.11.0/24 [110/3] via 192.168.100.1, 04:06:27, GigabitEthernet0/1
     10.0.0.0/24 is subnetted, 2 subnets
O       10.0.10.0 [110/2] via 192.168.100.1, 04:06:27, GigabitEthernet0/1
O       10.0.11.0 [110/2] via 192.168.100.1, 04:06:27, GigabitEthernet0/1
C    192.47.100.0/24 is directly connected, GigabitEthernet0/0 Shouldnt this forward the traffic for me?
C    192.168.100.0/24 is directly connected, GigabitEthernet0/1
S*   0.0.0.0/0 [1/0] via 192.168.100.3
S    192.47.0.0/16 [1/0] via 192.47.100.10
Here is the routing table for router2:
Gateway of last resort is 192.168.100.2 to network 0.0.0.0
O    192.168.11.0/24 [110/2] via 10.0.11.254, 04:23:37, GigabitEthernet0/1.11
C       10.0.10.0 is directly connected, GigabitEthernet0/1.10
C       10.0.11.0 is directly connected, GigabitEthernet0/1.11
C    192.168.100.0/24 is directly connected, GigabitEthernet0/0
S*   0.0.0.0/0 [1/0] via 192.168.100.2
Here is the routing table for router3:
Gateway of last resort is 192.168.100.1 to network 0.0.0.0
C    192.168.11.0/24 is directly connected, GigabitEthernet0/1
O       10.0.10.0 [110/2] via 10.0.11.1, 04:11:32, GigabitEthernet0/0.11
C       10.0.11.0 is directly connected, GigabitEthernet0/0.11
O    192.168.100.0/24 [110/2] via 10.0.11.1, 04:11:32, GigabitEthernet0/0.11
S*   0.0.0.0/0 [1/0] via 192.168.100.1
In summary, pinging router1 from router3 does not work, but pinging router3 from router1 does. Any help is appreciated, thanks!
Brad
Jon Marshall
Brad
When you ping from router 3 the source IP address will be 10.0.11.254.
But router 1 has no route for that subnet so it cannot send return packets.
So you need to add a route to router 1 for router 3's 10.0.11.0/24 subnet.
Alternatively you could configure mutual redistribution between OSPF and RIP if you wanted.
Edit - I know you said you could ping all the hops from router 1 to router 3 but I am not sure how as there is no route in the routing table for that subnet.
Jon
Seb Rupik
Hi Brad,
What does the <router ospf> configuration look like on router2?
cheers,
Seb.
Jon Marshall
Brad
Jon
