Routing problem - can't get to third subnet
jamie.mai
Hello, I am having a routing problem, everything was working and then something happened.
Thanks ahead of time for anyone attempting to read all this crap
I have 4 networks:
10.0.1.0 in a remote location (router is 10.0.1.253)
10.0.0.0 Here, main lan (router is 10.0.0.253)
192.168.10.0 DMZ, also here.
10.1.1.0/3 for point to point t1 (serial int)
Devices are using the routers as gateways with policies directing traffic to the Internet
or the t1 point to point
I also have 2 firewalls (sonicwalls) one at each location
10.0.0.254 which also hosts the DMZ on 192.168.10.1 int
10.0.1.254 at the remote location
The Sonicwalls have routes added for the remote traffic as follows:
Any 10.0.1.0/24 any 10.0.0.253 X0 (lan int)
Devices on 10.0.1.0 can no longer reach 192.168.10.0
What am I missing? I have a static route on the 10.0.1.253 router:
ip route 192.168.10.0 255.255.255.0 10.1.1.1
I have a static route on the 10.0.0.253 router:
ip route 192.168.10.0 255.255.255.0 FastEthernet0/1 10.0.0.254
This is what I get pinging from host 10.0.1.1 to the DMZ
Pinging 192.168.10.7 with 32 bytes of data:
Reply from 10.0.1.253: TTL expired in transit.
And traceroute:
Tracing route to www.generic.com [192.168.10.7]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 10.0.1.253
2 37 ms 1 ms <1 ms 10.0.1.253
3 1 ms 1 ms 1 ms 10.0.1.253
4 2 ms 1 ms 1 ms 10.0.1.253
5 2 ms 1 ms 1 ms 10.0.1.253
ICMP Debug on 10.0.1.253
004674: *Nov 8 09:19:19.685 CST: ICMP: redirect sent to 10.0.1.1 for dest 192.1
68.10.7, use gw 10.0.1.254
004675: *Nov 8 09:19:19.749 CST: ICMP: time exceeded (time to live) sent to 10.
0.1.1 (dest was 192.168.10.7)
004676: *Nov 8 09:19:20.697 CST: ICMP: redirect sent to 10.0.1.1 for dest 192.1
004677: *Nov 8 09:19:20.721 CST: ICMP: time exceeded (time to live) sent to 10.
004678: *Nov 8 09:19:21.713 CST: ICMP: redirect sent to 10.0.1.1 for dest 192.1
004679: *Nov 8 09:19:21.737 CST: ICMP: time exceeded (time to live) sent to 10.
004680: *Nov 8 09:19:22.725 CST: ICMP: redirect sent to 10.0.1.1 for dest 192.1
004681: *Nov 8 09:19:22.753 CST: ICMP: time exceeded (time to live) sent to 10.
show ip route (on 10.0.1.253)
Gateway of last resort is xxx to network 0.0.0.0
XX.0.0.0/30 is subnetted, 1 subnets
C XX.XX.XX.XX is directly connected, Serial0/1/0
S 192.168.10.0/24 [1/0] via 10.1.1.1
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 10.1.1.0/30 is directly connected, Serial0/0/0.1
D 10.0.0.0/24 [90/3847680] via 10.1.1.1, 1d17h, Serial0/0/0.1
C 10.0.1.0/24 is directly connected, FastEthernet0/1
XX.0.0.0/27 is subnetted, 1 subnets
C XX.XXX.XXX.xXX is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via XX.XX.XX.XX
Probably something stupid I am missing, router configs are attached. Any help would be much appreciated
Thanks!
Jon Marshall
These are the route map statements on your 10.0.1.253 router
access-list 198 permit ip 10.0.1.0 0.0.0.255 any
access-list 199 permit ip 10.0.1.0 0.0.0.255 10.0.0.0 0.0.0
route-map ToSonicwall permit 10
match ip address 199
set ip default next-hop 10.1.1.1
route-map ToSonicwall permit 20
match ip address 198
set ip next-hop 10.0.1.254
set ip default next-hop 10.0.1.254
Any traffic going to 192.168.10.x will match against access-list 198 and therefore be sent to the the sonicwall. Policy routing will override the normal routing table so your static is being ignored
Easiest way to fix is to add following line to access-list 199
access-list 199 permit ip 10.0.1.0 0.0.0.255 192.168.10.0 0.0.0.255
If you do this you do not need the static route
Jon
Jon Marshall
Jon
Yes! That did it, obvious after you pointed it out. I don't work on this stuff that often so it falls out of my head. Thanks a lot Jon!
