12-15-2015 06:33 AM - edited 03-08-2019 03:06 AM
I'm making a BGP network with 3 AS. I use 6 routers 3725.
I've making my routers configuration by reading these two links :
http://www.cisco.com/cisco/web/support/CA/fr/109/1094/1094968_bgp-toc.html
http://www.cisco.com/cisco/web/support/CA/fr/109/1093/1093302_23.html
Here is my topology.
Here is R5 configuration :
conf t
hostname R5
!---configuration physical interface
interface fastEthernet 0/0
ip addr 20.0.4.2 255.255.255.252
no shutdown
exit
interface fastEthernet 1/0
ip addr 192.168.5.253 255.255.255.0
no shutdown
exit
ip routing
!--- configuration eBGP link
router bgp 500
neighbor 20.0.4.1 remote-as 300
exit
!---configuration iBGP link
router bgp 500
neighbor 192.168.5.254 remote-as 500
exit
All router are configured in the same way.
My problem is, for exemple with my W7 I can't go out of my LAN ...
Where am I wrong ??
thanks
12-15-2015 08:45 AM
what is the ip address of W7 and i see the port is showing red on diagram.
-GI
12-16-2015 12:21 AM
192.168.1.1
It is marked in red because it is not turn on. But W7 pings it LAN as well as Kali & Ubuntu computer
By LAN I mean 192.168.1.0/24 and 20.0.2.1 because 192.168.1.254 is it default gateway.
12-16-2015 06:21 PM
have u even have any outside network in your routing table ,
R1#sh ip route
20.0.0.0/30 is subnetted, 1 subnets
C 20.0.6.0 is directly connected, FastEthernet0/0
C 192.168.1.0/24 is directly connected, FastEthernet1/0
u should have routes for wan networks in routing table to reach them advertise them with network command under router bgp AS no.
12-16-2015 12:54 AM
Can R1 and R2 see other subnets except own subnets? Do they see BGP neighbors R6, R3?
12-16-2015 01:52 AM
R1#sh ip route
R1#sh ip bgp summary
BGP router identifier 192.168.1.253, local AS number 100
BGP table version is 1, main routing table version 1
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
20.0.6.2 4 500 6 7 1 0 0 00:03:50 0
192.168.1.254 4 100 7 7 1 0 0 00:04:26 0
R2#sh ip route
C 20.0.2.0 is directly connected, FastEthernet0/0
R2#sh ip bgp summary
BGP router identifier 192.168.1.254, local AS number 100
20.0.2.2 4 300 8 8 1 0 0 00:05:16 0
192.168.1.253 4 100 8 8 1 0 0 00:05:24 0
I don't use any loopback interface to configure bgp, I would do it as simple as possible.
I think the problem is I don't see BGP route in my sh ip route command ... But why ??
EDIT : I think it a problem on my iBGP links because eBGP seems to work no ?
Here is a capture on f0/0 of R2.
Here is a capture on f1/0 of R2
So it the forwarding from iBGP toward eBGP which doesn't work ?
12-16-2015 08:54 PM
Hello ,
Lets do step by step by having neighbour ship between R1 and R6.
First are you able to ping the router interfaces , I hope yes.
Then create a eBGP neighbour ship between the two and advertise network and see are you able to see those network in routing table or not.
once done then create a igbo between R1 and R2 and you are seeing the routes in R2 table or not.
-GI
12-17-2015 01:27 AM
Yes I can ping the router interface in my LAN with W7 for exemple.
How do I advertise network ? I thought it was making in an automatic way...
Do I have to advertise eBGP network, iBGP netowrk or both ?
12-18-2015 10:55 PM
For exterior protocols the network command controls which networks are advertised.So from R1 under ebgp configuration
From R1 point of view ..configure the below
router bgp 100
neighbour R6 ip address remote-as 500
network 192.168.1.0 255.255.255.0
neighbour R2 ip address remote-as 100
and see in at R6 routing table are you able to see subnet advertise from R1 or not (192.168.1.0/24)
-GI
12-19-2015 01:32 AM
Hello
On your ebgp/Ibgp routers apply the next hop-self command facing the Ibgp peers as taking r5 as an example it will be advertising updates to R4 for sw3 as a next hop of 192.168.5.2 and not 192.168.5.1 . Also I don't see ibgp peering between r5 and r6 to establish a full Ibgp mesh
Lasty make sure R6/SW3/R5 have full connectivity to each other using either static routing or some igp (rip/eigrp/ospf) to negate the sychronisation rule
res
paul
