Routing Problem on 1921 router
frabro001
I am having trouble with the routing on my 1921, I am not able to ping host on either side of the interfaces but i can ping the interfaces, any help with the routing for this config, thanks all
My config is
no ip source-route
ip dhcp excluded-address 172.20.6.1 172.20.6.99
ip dhcp pool 6net
 network 172.20.6.0 255.255.255.0
 domain-name w0978domain.com
 dns-server 172.20.1.5 172.20.2.5 172.20.3.5
 default-router 172.20.6.30
ip domain name 33333333
ip cef
no ipv6 cef
cts logging verbose
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Connection to MPLS Circuit
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/0.631
 encapsulation dot1Q 631
 ip address x.x.x.x 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip verify unicast reverse-path
interface GigabitEthernet0/1
 description Inside-Interface MB Network
 ip address 172.20.1.252 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/0/0
 ip address 172.20.6.30 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/0/1
 no ip address
 shutdown
 duplex auto
 speed auto
router bgp xxxxx
 bgp log-neighbor-changes
 redistribute connected
 redistribute static
 neighbor xxxxxxxxxxx remote-as xxxxxxx
 default-information originate
no ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 172.20.1.30
snmp-server community public RO
access-list 23 permit 172.20.0.0 0.0.255.255
Philip D'Ath
Make sure everything has their default gateway pointing to the router for the VLAN they are on.
I guess routing could be disabled.  Try "ip routing".
What do you have connected to the interfaces ? A switch ?
Can you post the output from a traceroute ?
Julio E. Moisa
Is the the other end configured on the correct vlan? How is configured the port on the switch? it will not work if the switchport is configured as trunk, unless you create sub interfaces and router in a stick scheme is implemented.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
