10-13-2016 02:33 AM - edited 03-08-2019 07:47 AM
I have a routing problem on cisco 3560c with ipbase licence.
Topology as below:
I can ping from the Switch to MPLS router interface (10.7.0.254) and to other networks behind mpls router. I can also ping from vlan 11 SVI to vlan 10 SVI.
Issue:
I cannot ping from vlan 11 SVI to MPLS router interface.
I have another site with very similar config, if not the same and it all works fine. The only difference is that on the other site I have 3750x, however I believe ipbase licence on 3560c should provide all basic routing services.
Please see the config below:
3560c#sh run
Building configuration...
no aaa new-model
system mtu routing 1500
ip routing
ip dhcp pool DATA_LAN
network 10.7.1.0 255.255.255.0
default-router 10.7.1.1
domain-name xxx
dns-server 4.2.2.1
no ip domain-lookup
ip domain-name xxx
vtp mode transparent
spanning-tree mode rapid-pvst
spanning-tree vlan 1-4094 priority 12288
vlan internal allocation policy ascending
vlan 10
name TRANSIT
vlan 11
name DATA_LAN
interface GigabitEthernet0/2
switchport access vlan 11
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/8
description LINK_TO_BT_MPLS_ROUTER_ge0/1
switchport access vlan 10
mls qos trust cos
interface Vlan1
no ip address
shutdown
interface Vlan10
description TRANSIT
ip address 10.7.0.1 255.255.255.0
interface Vlan11
description DATA_LAN
ip address 10.7.1.1 255.255.255.0
ip default-gateway 10.7.0.254
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.0.1 name INTERNET
ip route 10.0.99.0 255.255.255.224 10.7.0.254
ip route 10.0.99.32 255.255.255.224 10.7.0.254
ip route 10.0.99.64 255.255.255.224 10.7.0.254
ip route 10.0.99.253 255.255.255.255 10.7.0.254
ip route 10.1.0.0 255.255.240.0 10.7.0.254
ip route 10.2.0.0 255.255.240.0 10.7.0.254
ip route 10.3.0.0 255.255.240.0 10.7.0.254
ip route 10.4.0.0 255.255.248.0 10.7.0.254
ip access-list extended VTY-access
permit tcp 10.0.99.0 0.0.0.255 any eq 22
permit tcp 10.255.254.0 0.0.0.255 any eq 22
deny ip any any
On some other thread regarding similar issue on 3750x I found the following solution:
- do a no ip routing
- save the config
- backup config to flash
- erase startup config
- reload the 3750x switch
- copy config from flash to run
- enter command ip routing
However I`m not on site and have only remote access at the moment, so I would prefer to find another solution. Besides, the above was on 3750x and apparently there was some glitch somewhere. Mine 3750x works fine, just have an issue with 3560c.
Thanks in advance.
Krystian
10-13-2016 03:04 AM
It is very simple your MPLS router do not have route for vlan 11 10.7.1.0/24.
You can configured static route on MPLS router as
ip route 10.7.1.0 255.255.255.0 10.7.0.1
10-18-2016 01:43 AM
@Saratpha
Thanks for the post, however in this case it turned out that ISP put wrong subnets in the routes on MPLS router.
As soon as they corrected it it worked.
@Pawan Raut
Many thanks for fast reply and helping to sort out the issue.
10-18-2016 12:08 AM
You can run any dynamic routing protocol between VLAN 10 SVI and MPLS router to advertise VLAN 11 subnet.
Or you can do the static or dynamic NAT or NAT-PAT to convert the source IP address
