Routing problems between VLANs
hepterida
Community Member
on Cisco Catalyst infrastructure, there has been two VLANs. One for switch communications (VLAN1). Second for client communication (VLAN10).
Every switch has an uplink in trunk mode, so everything works fine.
The problem is, when I added a new VLAN77 e.g. This VLAN was defined on VTP server (Cisco Catalyst 3750) and user on VTP client (Cisco Catalyst 2950) on dedicated ports (reserved for VLAN77 only).
DeviceIOSIPVLAN
Cisco Catalyst 3750 (vtp server)12.2(55)SE1-IP-BASE-CRYPTO
10.1.0.232
10.3.0.1
VLAN10
VLAN77
Cisco Catalyst 2950 (vtp client)12.1(22)EA14-C2950-I6Q4L2-M10.1.0.245VLAN10
Cisco ASA 5510 (f/w)
10.1.0.252
Even if the vtp server has set the route 0.0.0.0 0.0.0.0 10.1.0.252, VLAN77 cannot reach external networks or other VLANs.
Only access from VLAN77 to VLAN10 is from device on port dedicated for VLAN77. But only to 10.1.0.232 IP address could this 10.3.0.2 device ping.
Where could be the problem?
2 Accepted Solutions
It is also stated that there is a default route 0.0.0.0 0.0.0.0 10.1.0.252 from the 3750 to the ASA
but does the ASA have a route back to 10.3.0.0
Alex
Regards, Alex. Please rate useful posts.
Amit Singh
Alex pointed out correctly to check if ASA as a roiyer back to Vlan 77. Also on your 2950 (VTP Client), Please could you add a command " ip default-gateway 10.1.0.232". You should be able to ping 2950 after you add that command.
Hope this helps.
Cheers,
-amit singh
12 Replies 12
cadet alain
the default gateway of this dvice must be the interface VLAN 77 Ip address on the 3750, is this the case?
are you sure the vlan 77  was advertised by vtp ? : sh vlan br
Can you post output on 2950 from sh int trunk and sh int x/x switchport where x/x is interface where this devices is connected.
Regards.
Alain
Alex
This is the "show vlan brief" command from 3750:
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/2, Gi1/0/24
2    Guest                            active
10   office                           active    Gi1/0/3, Gi1/0/4, Gi1/0/5
                                                Gi1/0/6, Gi1/0/7, Gi1/0/8
                                                Gi1/0/9, Gi1/0/10, Gi1/0/11
                                                Gi1/0/12, Gi1/0/13, Gi1/0/14
                                                Gi1/0/15, Gi1/0/16, Gi1/0/17
                                                Gi1/0/18, Gi1/0/19, Gi1/0/20
                                                Gi1/0/21, Gi1/0/22, Gi1/0/23
77   Vodafone_FemtoCell               active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
And this is trunk show of 2950:
Port        Mode         Encapsulation  Status        Native vlan
Gi0/2       on           802.1q         trunking      1
Port      Vlans allowed on trunk
Gi0/2       1-4094
Port        Vlans allowed and active in management domain
Gi0/2       1-2,10,77
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/2       1-2,10,77
2950: And sh int Gi0/2 switchport - uplink:
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
2950: And show switchport on dedicated port for VLAN77:
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 77 (Vodafone_FemtoCell)
Voice VLAN: none
Protected: false
Amit Singh
Hope this helps.
Cheers,
-amit singh
Hi Amit,
thank you for your tip. I added "ip default-gateway" command, and now I can ping 10.1.x.x and 10.3.x.x networks from 2950 device.
Now, I cannot ping from device connected to 2950 port to other IPs than 2950's IP and 10.1.0.232 IP.
    Make sure that you have VLAN77 in VLAN database on C2950.
    Make sure that you correctly assign VLAN77 to access port on C2950
    Make sure that you have vlan interface 77 on C3750.
    Make sure that you turn on "ip routing" on C3750.
    Make sure that you correctly configure a gateway on hosts in VLAN77
HTH,
Toshi
hepterida
Community Member
For better understanding
    What's the cloud in your picture?
Toshi
All clouds are is one (the same) internal LAN.
Can you ping the default gateway for VLAN 77 from VLAN 77? If so, since there is a default route going to the ASA, can you verify that there is a route back to VLAN 77 from the ASA? You should see something like...
route inside 10.3.0.0 255.255.255.0
You, acampbell and Amit were right. An ASA routing has been forgotten 🙂
Now I can ping all devices and ASA from VLAN77. Thank you all!
