Routing Traffic locally
UKDanny666
Hi there,
Just starting out on my journey to become certified. Working through the pluralsite videos amongs other material.
Just got to the basic configuration of a cisco router segment, basically I am connecting two laptops to the fast ethernet ports of my cisco router.
interface FastEthernet0/0
 ip address 10.0.0.1 255.255.255.128
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 10.0.0.129 255.255.255.128
 duplex auto
 speed auto
Configured my end devices with a corresponding valid host address, and tried to ping each machine from oneanother.
Each machine can only hit their f/e ports, traffic does not seem to pass to the other network.
Appreciate this may be a small error compared to the other subject on here, but we all gotta start somewhere.
Thanks in advance
Danny
PS full running config if needed below.
hostname Danny_Router_01
enable secret 5 $1$UHKv$am09k.5Tc7aUheY4CPEUk0
ip domain-name dannytest.com
 duplex auto
 speed auto
 duplex auto
 speed auto
interface Serial1/0
 no ip address
 shutdown
 no fair-queue
interface Serial1/1
 no ip address
 shutdown
interface Serial1/2
 no ip address
 shutdown
interface Serial1/3
 no ip address
 shutdown
interface Serial1/4
 no ip address
 shutdown
interface Serial1/5
 no ip address
 shutdown
interface Serial1/6
 no ip address
 shutdown
interface Serial1/7
 no ip address
 shutdown
ip classless
ip http server
line con 0
 password 7 14341B180F0B
 logging synchronous
 login
line aux 0
 password 7 0802455D0A16
 logging synchronous
 login
line vty 0 4
 login
end
Is it a lab?
Please share tracert command output from the windows machine.
I think you are connected with some other connection as wifi at the same time on the lab system. If yes, then please disconnect the wifi or other connection to the lab system and test it again.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
7 Replies 7
Deepak Kumar
Kindly verify the correct default gateway on both networks and disable the firewall on both machines (for temporary).
Deepak Kumar
Deepak Kumar,
In addition to Deepak's suggestions, post the output of 'ipconfig /all' of both laptops...
UKDanny666
Many thanks for the replies,
So on the laptop connected to fe0/0
Ip: 10.0.0.10
Sn 255.255.255.128
Dg: 10.0.0.1
laptop on fe 0/1
ip: 10.0.0.130
sn: 255.255.255.128
dg: 10.0.0.129
Both laptops have had f/walls disabled to no avail:(
I’ve also tried using the ip routing command, just in case that’s disabled but again no success.
thanks again
Danny
Is it a lab?
Deepak Kumar
Deepak Kumar,
When I read the original post I believed that the most likely issue was firewalls on the PCs. If both PC firewall are disabled then we need to look for other issues. Can you post the output of these commands on the router
show ip interface brief
show arp
Additional questions:
- can each PC ping the router interface to which it connects?
- can the router ping each of the connected PCs?
Rick
Rick
Hi Richard
Thanks for the input turns out Wireless was still on.
Danny
Deepak,
Many thankyous
I left the WiFi on one of the laptops. All traffic routing, on what should have been a fairly straight forward lab.
Danny
