routing troubles
kathaleya
Frequent Visitor
Frequent Visitor
Hi & aloha - first time reaching out for some help..    I have a server online that recently moved to a new space and is currently on a new switch. Since the move, I have been unable to ping / access the server from our user vlan -70.  From the core switch i can ping the server IP address but when i try to ping from source vlan 70,  the pings fail.  As a temporary fix, I move the users to vlan 20 and they can now access the server - but i'd really prefer to fix it properly.  Im not really sure where to start t-shooting.
Help please 🙂
Where is your server connected ?
what is the server vlan ?
is server L3 vlan and user Le vlan both configured on the same switch or different switch
if its different switch, are those switch connected using trunk link and passing all the vlans ?
kindly provide the above details and will be able to help you to fix the issue
Basavaraj
