routing using eigrp
carl_townshend
Hi all, I was reading some info on eigrp with the auto summary command switched on, If I have say 5 routers say on 10.1/16 10.2/16 10.3/16 10.4/16 and 10.5/16 each connected via an ethernet port in the 192.168.1.0/30 range, will they see each other with the correct mask or will it auto summarize them to a 10 network and so will not work ?
paul.matthews
Level 10
Level 10
It will summarise, and thus not work properly.
Paul.
