SWITCH PORT ACCESS
dlgoodson
Community Member
Is it possible to configure a port for a host to view all other hosts on different vlans?
ankbhasi
Hi Friend,
Is this a layer 3 switch? I believe what you are looking is a routing between vlans which is not possible without having configure inter vlan routing on switch.
Ankur
paul.matthews
Level 10
Level 10
You could span all vlans to the port.
Why do you want to do that?
Bear in mind that if you have either a router or an L3 switch, you can route between the VLANs andhosts can see each other anyway.
Paul.
i have a cat 4500 series but i can only view host on my vlan.
