RRoCE v2.0 mode was requested, but it is not supported.
Walter Dey
Customer is using N5k, connecting W2012 R2 host, as well as a W2012 R2 host acting as a SMB3 fileserver.
They use RDMA over Converged Ethernet (RoCE), and receive the following error message
SingleFunc_32_0_0: RRoCE v2.0 mode was requested, but it is not supported. The NIC starts in RRoCE v1.5 mode.
NOTE: If your environment contains mix of different NIC types, you need to make sure that the whole environment is configured to use the same RoCE mode,
otherwise the traffic between the different NICs does not work.
interface Ethernet1/13
priority-flow-control mode on
flowcontrol send off
flowcontrol receive off
end
Global QoS Config
class-map type qos match-any class-rdma
  match cos 3
class-map type queuing class-rdma
  match qos-group 4
policy-map type qos rdma-policy
  class class-rdma
    set qos-group 4
  class class-default
policy-map type queuing rdma-queuing-policy
  class type queuing class-rdma
    bandwidth percent 60
  class type queuing class-default
    bandwidth percent 40
class-map type network-qos class-rdma
  match qos-group 4
policy-map type network-qos rdma-network-policy
  class type network-qos class-rdma
    pause no-drop
  class type network-qos class-default
    multicast-optimize
system qos
  service-policy type network-qos rdma-network-policy
  service-policy type qos input rdma-policy
  service-policy type queuing input rdma-queuing-policy
  service-policy type queuing output rdma-queuing-policy
The end to end link is not working ? Any hints what could be wrong ?
0 Replies 0
