RSA with remote vpn !
Jonn cos
Level 4
Level 4
Hi all experts.
I am using Cisco 3845 router with adv security k9 IOS. I am currently using easy vpn server and several our users are using it for years now. Its all stable and working perfectly. Now i was thinking of setting up RSA token with it. Since i am a bit newbie to this concept, if someone can take out some time and help me how to set RSA tokens with easy vpn. I am using Cisco secure 3.3 on windows.
So to setup RSA token, so that users need to enter a different RSA pass (or whatever its called) everytime he needs to log in. What components i need ? If possible kindly guide and also refer me some good link on that
Latchum Naidu
Hi John,
See the below link would help you in the way how to setup RSA for easy vpn users and what components needed to setup it.
http://www.cisco.com/en/US/docs/ios/sec_secure_connectivity/configuration/guide/sec_easy_vpn_rsa.pdf
Please rate the helpfull posts.
Naidu.
