can't communicate on L3 on specific interfaces
3moloz123
I have a Cisco 2821 with 2x HWIC-4ESW. Two of the ports on the first module (range 0/0/1-2) are access ports, with one vlan each. The vlans has ips configured in /30 nets, where the other usable address are ebgp neighbours. The port Im trying to use for management is on module number 2 (0/1/3).
Seems to me it's identical hwics, see output of 'show inventory'.
So port 0/1/3 has vlan 999, and vlan 999 is configured with address 10.1.0.132/25. I configured 0/1/2 as vlan 999 too, connected a laptop and it can ping through the router to the switch connected on 01/3 - but not other device can reach the routers ip 10.1.0.132, and the router cant reach any of the devices on 10.1.0.128/25.
To sumarize the problem: I can ping the other hosts in vlan 100 and vlan 101, but not the other hosts in vlan 999.
It's connected  like this:
       <laptop>
<router>
       <switch_with_vlan999>
                       <other_devices_on_vlan999>
# show version
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821         , VID: V05 , SN: FCZ123456
NAME: "4 Port FE Switch on Slot 0 SubSlot 0", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW         , VID: V01 , SN: FOC123456
NAME: "4 Port FE Switch on Slot 0 SubSlot 1", DESCR: "4 Port FE Switch"
# show run
interface FastEthernet0/0/0
description a specific IX
switchport access vlan 101
no cdp enable
interface FastEthernet0/0/1
description specific ISP
switchport access vlan 100
no cdp enable
interface FastEthernet0/1/3
description network management
switchport access vlan 999
interface Vlan100
description specific isp
ip address 1.2.3.150 255.255.255.252
no ip proxy-arp
interface Vlan101
description some IX
ip address 2.3.4.70 255.255.255.192
no ip proxy-arp
interface Vlan999
ip address 10.1.0.132 255.255.255.128
no ip proxy-arp
# show ip interface brief
FastEthernet0/0/0          unassigned      YES unset  up                    up
FastEthernet0/0/1          unassigned      YES unset  up                    up
FastEthernet0/1/3          unassigned      YES unset  up                    up
Vlan1                      unassigned      YES NVRAM  up                    down
Vlan100                    1.2.3.150  YES NVRAM  up                    up
Vlan101                    2.3.4.70  YES NVRAM  up                    up
Vlan999                    10.1.0.132      YES manual up                    up    <- does manual mean "not yet saved to startup-config", or is it an indicator of a difference between hwic 1 and hwic 2?
2 Accepted Solutions
And now while investigating, I suddently found a third mac address on the router:
0017.0e8d.3c0d Dynamic     999     FastEthernet0/1/3
0023.4719.a920 Dynamic     999     FastEthernet0/1/3
f062.8195.f100 Dynamic     999     FastEthernet0/1/3
# show arp
Internet  10.1.0.143              0   0017.0e8d.3c00  ARPA   Vlan999
But not vice versa:
Internet  10.1.0.132              0   Incomplete      ARPA
The new mac addresses correspond to a HP procurve gears ,  is it normal?
Can you do a sh cdp nei .
Regards.
Alain.
   If you are running 2 hwic 4 esw's you have to stack them together to work correctly,
You have to tie one port from one hwic to aniother port on the other hwic , otherwise
it won't work correctly. Has this been done? If not they will work as isolated switches.  Go here to see how to configure stacking. http://www.cisco.com/en/US/docs/ios/12_3t/12_3t8/feature/guide/esw_cfg.html#wp1049119
Stacking of Cisco 10/100BASE-T Ethernet Switch HWICs
Stacking is the connection of two Ethernet switch HWICs resident in the  same chassis so that they behave as a single switch. Stacking is  accomplished by daisy-chaining the two cards together with an external  RJ-45 crossover cable that is connected to the specified stacking port  on each switch.
When a chassis is populated with two Ethernet switch HWICs, the user must configure the cards to operate in stacked mode.
Note There  is no option to unstack two Ethernet switch HWICs. When two Ethernet  switch HWICs are in the same chassis, they can operate only in stacked  mode. If you configure the cards to operate unstacked, they will not  operate correctly.
You must designate one port on each switch to be the stacking port. On  the HWIC-4ESW card, this port is nominally the first port (port 0),  although any port can be chosen. On the HWIC-D-9ESW card, this port is  nominally the ninth port (port 8), although any port can be chosen. We  recommend the use of port 8 as the stacking port, because it has been  designed as an extra port on the HWIC-D-9ESW card and does not provide  inline power.
Note Only one port on an Ethernet switch HWIC can be configured as a stacking port.
All combinations of Ethernet switch HWICs may be stacked: two  HWIC-D-9ESW cards, an HWIC-D-9ESW card with an HWIC-4ESW card, or two  HWIC-4ESW cards.
See the Configuration Guidelines for HWIC-4ESW and HWIC-D-9ESW Interface Cards document for information on how to configure stacking ports.
27 Replies 27
cadet alain
but not other device can reach the routers ip 10.1.0.150
How come this IP is not in the sh ip int br output?
Regards.
Alain.
Sorry, that's a typo. 10.1.0.132 as per the configuration is correct - and not pingable from any device connected to vlan 999.
Edit: to clarify, not only not pingable, but not reachable in any way. Tried adding acls for ssh/telnet and debugging it with no go. Cannot find any of the other devices in 999 in arp list either.
Can you clarify? if you put a PC in a port belonging to VLAN999 you can't ping int VLAN999 and there is no entry in the arp table for this PC?
Regards.
Alain.
Exactly.
I connected a laptop to 0/1/2, configured the interface to be an access port in vlan 999.
The laptop can't reach the router on 10.1.0.132, but it can however reach devices that are connected to the switch (which in term is connected to 0/1/3 on the router).
        0/1/2
<2821>
        0/1/3
So both 0/1/2, 0/1/3 and the ports on the switch are all access ports in 999. The laptop can reach "other devices" and vice versa, but no one can reach the routers 10.1.0.132, and the router has no arp entries with ips that matches the devices..
laptop: 10.1.0.133
Some of the other devices include: switch 1 10.1.0.141, switch 2 .142, switch 3 .143 etc etc..
Trying to reach .141:
# show arp
Internet  10.1.0.132              -   0026.994c.6560  ARPA   Vlan999
Internet  10.1.0.141              0   Incomplete      ARPA
edit: the only reason FastEthernet 0/1/2 is not configured in the config shown earlier, is that I only used it to make sure that I could actually use the ports as Layer 2, ie ping from a laptop in 0/1/2 to something connected behind 0/1/3 - and because it worked I removed the configuration and continued using only 0/1/3.
So you can reach  .141 from .133 but don't see any arp entries for .141 ? But  IMHO this is normal behaviour because they are in the same VLAN and so this pure L2  switching.
Can you post sh ip route and sh run | s ip routing as well  as sh run | in ip default
Regards.
Alain.
Yes, I understand. But I should see the arps if I try to ping any other host in 10.1.0.128/25 I should get arp entries of them.
# sh ip route
B*    0.0.0.0/0 [20/10] via 195.67.149.9, 7w0d
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.1.0.128/25 is directly connected, Vlan999
L        10.1.0.132/32 is directly connected, Vlan999
<200 other routes not included>
# sh run | s ip routing
returns nothing
# sh run | in ip default
returns nothing
Yes but if you ping from the router itself not from host to host.
Regards.
Alain.
The router cannot ping any device in 10.1.0.128/25, and no device in 10.1.0.128/25 can ping the router (on 10.1.0.132).
Can you post output of sh access-list and sh ip int Vlan999
Regards.
Alain.
Standard IP access list 21
    10 permit 4.5.6.109 (1356606 matches)
Standard IP access list 23
    20 permit 4.5.8.0, wildcard bits 0.0.0.255
Standard IP access list 24
    10 permit x.y.105.126
Standard IP access list 25
    10 permit 10.1.0.0, wildcard bits 0.0.0.7
Extended IP access list 101
    10 permit ip host 7.8.9.126 any (6 matches)
    20 permit ip 10.1.0.0 0.0.0.255 any
    30 permit ip host 7.7.7.40 any (18 matches)
Vlan999 is up, line protocol is up
  Internet address is 10.1.0.132/25
  Broadcast address is 255.255.255.255
  Address determined by setup command
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is disabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP Null turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  Input features: MCI Check
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
ok,
ping a host in Vlan 999  from your router and at same time debug arp  and post output
Regards.
Alain.
Sending 5, 100-byte ICMP Echos to 10.1.0.141, timeout is 2 seconds:
Apr 26 09:48:04: ARP TABLE: inserting entry 10.1.0.141/0000.0000.0000 on Vl999 for Incomplete
Apr 26 09:48:04: IP ARP: creating incomplete entry for IP address: 10.1.0.141 interface Vlan999
Apr 26 09:48:04: IP ARP: sent req src 10.1.0.132 0026.994c.6560,
                 dst 10.1.0.141 0000.0000.0000 Vlan999.
Apr 26 09:48:06: IP ARP throttled out the ARP Request for 10.1.0.141
Apr 26 09:48:08: IP ARP: sent req src 10.1.0.132 0026.994c.6560,
Apr 26 09:48:10: IP ARP: sent req src 10.1.0.132 0026.994c.6560,
Apr 26 09:48:12: IP ARP: sent req src 10.1.0.132 0026.994c.6560,
Is .141 receiving the arp request ? Can you sniff the interface ? If yes is it replying?
Can you also do  ipconfig/all to query mac of .141 and then a sh mac address( or show mac-address) dynamic Vlan 999 | xxxx.xxxx.xxxx where xxxx.xxxx.xxxx is the mac address of .141
Regards.
Alain.
# sh ip route
L        10.1.0.132/32 is directly connected, Vlan999     << should this be in your routing table? possible overlapped subnet..?
# show ip interface brief                                             <<<-- in your output there is no FastEthernet0/1/2 (where your laptop is connected)?
another is, check the laptop/PC if it has configured a default gateway to 10.1.0.132 and laptop subnet mask is 255.255.255.128
regards
