RSPAN across 2 x Nexus 7009 Core switches
rickysahni
Switching
My DC Core Switches comprise of 2 x Nexus 7009 switches running with VPC configured between them. They run in Primary Secondary mode.
I have a SPAN destination port setup on Primary Core switch which is connected to an appliance that collects the date.  However i also need some source ports on Seconday Core switch to pass to the destination interface on Primary Core switch via an RSPAN.
Any ideas on the best way to do this?
marce1000
 https://www.cisco.com/c/en/us/support/docs/switches/nexus-7000-series-switches/113438-rspan-nexus-7000-00.html
 M.
Great thank you M
Will take a look
Can i just ask if i can add the new RSPAN Vlan across an already used VPC link between the 2 Nexus Core switches that has other multiple vlans going across it?
Or would i need to add another physical link between N1 and N2 that is just dedicated for the RSPAN Vlan?  As i see in the ciso doc they ask for one side of the link to be configured as an access port in Vlan 15.
