07-30-2015 05:10 AM - edited 03-08-2019 01:10 AM
hi
I need a copy internet trafic.
Have a such network topology from Cisco to VM:
2960 - 3750 - cisco 3120 -
- VMWare dSwitch - vNic VM
- hp procurve 6120xg -
//RSPAN on the 2960
vlan 61
remote-vlan
interface FastEthernet0/2
description ===== Internet-inside =====
switchport access vlan 950
switchport mode access
//this port connected to the 3750.
interface FastEthernet0/12
description ===== SPAN_INET =====
switchport trunk allowed vlan 61
switchport mode trunk
//this port is also connected to the 3750.
monitor session 1 source interface Fa0/2
monitor session 1 destination remote vlan 61
3750:
//different vtp domain
vlan 61
remote-vlan
interface GigabitEthernet2/0/3
description ===== Internet =====
switchport access vlan 193
//port fa0/2 from 2960 with Internet-traffic.
interface GigabitEthernet3/0/10
//port fa0/2 from 2960 with copy Internet-traffic.
interface TenGigabitEthernet3/0/1
description ===== BLADE_TRUNK_MEMBER 6120s09 =====
switchport trunk native vlan 500
switchport trunk allowed vlan 1,2,4,5,7,50,51,60-62
switchport nonegotiate
//trunk to the hp 6120xg
on the hp procurve 6120xg:
vlan 61
name "SPAN"
tagged 1-16,22
no ip address
exit
//1-16 ports - is a host's, 22- trunk to the 3750
I did some research and figured out that if Vm is on the physical host behind hp procurve blade switch 6120xg - no mirrored trafic at all. Although if Vm is on the physical host behind Cisco blade switch - have mirrored traffic on VM vNIC. I've checked out with wireshark on Windows OS.
Is smth wrong with 6120xg tagging? Maybe 6120xg somehow wiping original vlan of frame...
No problem with CIsco blade switch.
Have a lot of vlan on production procurve and in setting it on Vmware portGroup - have no problem, problem is with RSPAN Vlan only.
Solved! Go to Solution.
07-31-2015 02:09 AM
Hitesh, Maxim,
Hitesh: You are correct that if the destination switch was a Cisco switch, Maxim would need to configure a destination RSPAN session. However, the destination switch is a HP switch and it is not certain if it supports anything similar to RSPAN.
Maxim: In my opinion, the primary reason why your VMs do not see the mirrored traffic is that the HP switch does not handle VLAN 61 in any special way. However, the biggest operational difference of a RSPAN VLAN to regular VLANs is that in RSPAN VLAN, no MAC address learning shall be performed so that the mirrored traffic is always flooded across the whole RSPAN VLAN, wherever the destination switch might be. If your HP switch performs MAC address learning in VLAN 61, it most probably does not flood the mirrored traffic to the monitoring device simply because the destination MAC address seems to be connected elsewhere.
The first thing you should try to find out is to check whether the HP switch also has a concept of RSPAN VLAN (note that it can be called differently - I have no idea about the possible name, though), and if so, make sure that the VLAN 61 is treated as an RSPAN VLAN by the HP switch. If not, try to find out whether it is at least possible to deactivate MAC address learning in VLAN 61 on the HP switch.
Best regards,
Peter
07-30-2015 11:16 PM
I think you would need to create destination SPAN from RSPAN VLAN
Beginning in privileged EXEC mode, follow these steps to create an RSPAN destination session, to specify the source RSPAN VLAN, and to enable ingress traffic on the destination port for a network security device (such as a Cisco IDS Sensor Appliance):
This example shows how to configure VLAN 901 as the source remote VLAN and how to configure the destination port for ingress traffic on VLAN 5 by using a security device that supports 802.1Q encapsulation:
Switch(config)# monitor session 1 source remote vlan 901
Switch(config)# monitor session 1 destination interface fastEthernet0/5 ingress vlan 5
Switch(config)# end
07-31-2015 02:09 AM
Hitesh, Maxim,
Best regards,
Peter
08-29-2019 08:14 AM - edited 08-29-2019 08:21 AM
As Peter Paluch said, traffic in RSPAN VLAN is copied to all ports in that VLAN except for incoping port. So switches that don't support RSPAN conception must act like hubs for that VLAN. Since hubs as layer 1 devices don't support MACs we only need to disable MAC learning for particular VLAN on managed switches.
For example for H3C models it could be done like:
vlan xxx mac-address mac-learning disable
BUT if switch already learned some MACs after disabling learning we need to delete them in order to switch start sending packets into other ports. It could be done from system-view like:
undo mac-address vlan xxx
08-02-2015 12:29 AM
Peter.
Yes. Your are so close to correct answer. I have found out that the problem was in the enabled storm (broadcast) control on the HP Procurve switch. And that dumb switch didn't know anything about RSPAN VLAN. It have to increase level of permited flood trafic or disable this feature at all to resolve an issue. Thanks for you opinion and help.
