RSPAN for 4500X as Core with Multiple Access Switches with 1 Session
azhar_eaggle1
we have 4500X as core and trying to run RSPAN for all access Ports on Access Switches(3850 Stacked). access Switches to the core is on L2 and we are trunking all VLANs. when we send Captured packets to Core, it also sends to other access Switches. wants to Limit RSPAN traffic. so that Core should only be Ingress not Egress. any idea, how we can do that
joseph.h.nguyen
It sounds like you configure RSPAN correctly based on that it is working but not the desired result.  Here is a configuration guide anyway, https://community.cisco.com/t5/networking-documents/understanding-span-rspan-and-erspan/ta-p/3144951.
No idea of your configuration.  If you can post it, we may be able to help.  Have you configured your trunk port to prune VLANs?  Pruning restricts VLAN outbound to other switch.  See sample config, https://learningnetwork.cisco.com/thread/119664.  First thing popped in my head is that the RSPAN VLAN is extended from core switch to other access switches or core sw's monitor session destination may be misconfigured.
See Below Configs. we want to stop inter Switch Communication for access Switches for VLAN-999
!Core Switch
VLAN 999
name span
remote-span
monitor session 1 destination interface Te1/1/10
monitor session 1 source remote VLAN 999
monitor session 1 filter packet-type good rx
!Switch 01
VLAN 999
name span
remote-span
monitor session 1 source VLAN 100,300
monitor session 1 destination remote VLAN 999
Have you checked your trunk ports?  Do "show interface trunk", if you see VLAN 999 specified or within the range, than it is inter switching.  To prune vlans on trunk port, you have to add "switchport trunk allowed vlan except 999" on the desired trunk port(s).
