RSPAN... limiting VLAN sources?!?
andyroles
Hi there,
I posted this thread a few days ago but didn’t manage to get to the  bottom of the issue then. Thank you to Giuseppe for his contribution to  that thread.
The RSPAN config shown at the bottom of this thread isn’t doing as I expected. I want to only see the output from 3 voice VLANs (32,34 and 36) that are configured across two switches (connected by a VLAN trunked L2 port channel).
The problem is:   Currently I’m seeing traffic from all VLANs for the switches when sniffing the port gig 7/10 on SW01.
Configured across the trunk are VLANs 1, 32, 33, 34, 35, 36, 39, 40, 41, 42, 44, 45, 46,47 and 951 (remote-span vlan).
Strangely, if I only configure one vlan source e.g. VLAN 32 within the contect 'monitor session 1 type rspan-source' then that is the only traffic that I see (as i would expect). As soon as I add more VLAN sources to the list however then traffic from all VLANs start to show up in the Wireshark trace?
The configuration I've applied is shown below.  Any comments welcome.
DISTRIBUTION SW 01 -
vlan 951
name RSPAN_VLAN_951
remote-span
spanning-tree vlan 951 priority 8192
interface Port-channel1
switchport trunk allowed vlan add 951
source vlan 32 , 34 , 36
destination remote vlan 951
monitor session 11 type rspan-destination
source remote vlan 951
destination interface Gi7/10
interface GigabitEthernet7/10
description ** VOICE RECORDING PORT **
switchport
speed 1000
duplex full
end
DISTRIBUTION SW 02 -
Vlan 951
name RSPAN_VLAN_951
remote-span
spanning-tree vlan 951 priority 16384
we're currently running - disk1:/s72033-ipservices_wan-mz.122-33.SXH4.bin
Many thanks in advance and thanks for reading my post –
Andy
8 Replies 8
Giuseppe Larosa
Hello Andy,
looking at the configuration guide I have found the feature of Vlan filtering on destination port that might help
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/span.html#wp1147320
It says that if you configure the destination port, the one connected to the network analyzer, as a trunk port with a list of allowed vlan = 32,34,36 you should see only frames belonging to these three vlans
Hope to help
Giuseppe
Guiseppe.  Thanks. This sounds like a solution. I'm keeping my fingers crossed.  Thank you for all your help.
Robert R
Hi Andy,
I'm not sure what platform you're running this on, but we use Catalyst 4500 and 6500 series for this, and this is how we do it.
Assuming your trunking and vlans are setup correctly (and they appear to be)
Distribution SW02
monitor session 1 source interface
monitor session 1 filter vlan 32, 34, 36
monitor session 1 destination remote vlan 951
Distribution SW01
monitor session 1 source remote vlan 951
monitor session 1 destination interface gi 7/10
I haven't had much success rspanning a source vlan, plus for our purposes, we were only interested in certain interfaces voice traffic, and not the whole vlan.
Hope that helps.
Rob
Rob, many thanks for this.  I think this would work fine for a relatively small number of ports but i need to monitor 4 blades worth of interfaces! and I think  this method is limited by the number of interfaces that can be monitored.  Thanks again for your feedback tho.
Andy,
Glad to help, are the interfaces solely on the remote switch SW02? or are there some on SW01 as well? I ask because according to the following document, your configuration of SW01 is not supported.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml#sameID
Towards the bottom is the following excerpt.
Can a RSPAN Source Session and the Destination Session Exist on the Same Catalyst Switch?
No. RSPAN does not work when the RSPAN source session and the RSPAN destination session are on the same switch.
If an RSPAN source session is configured with a particular RSPAN VLAN and an RSPAN destination session for that RSPAN VLAN is configured on the same switch, then the RSPAN destination session's destination port will not transmit the captured packets from the RSPAN source session due to hardware limitations. This is not supported on the 4500 Series and 3750 Series Switches. This issue is documented in Cisco bug ID CSCeg08870 (registered customers only) .
This is an example:
monitor session 1 source interface Gi6/44
monitor session 1 destination remote vlan 666
monitor session 2 destination interface Gi6/2
monitor session 2 source remote vlan 666
The workaround for this issue is to use the regular SPAN.
It appears as if you will need a third switch to act as the destination of the RSPAN and simply use SW01 as another source for the vlans into the remote vlan 951.
Rob
Another "funny thing" you can do, if you dont have a third switch, is to make a physical loop between the destination interface of the RSPAN and another interface (i know, thats really bad ), and configure it as source of a new SPAN  together with your local port..
monitor session 2 destination interface Gi6/45
#  Gi 6/45 is looped on Gi 6/46
monitor session 1 source interface Gi6/44, interface Gi/46 monitor session 1 destination Gig6/2
# Gig 6/2 is plugged on the analyzer
Thanks Bruno.
I think i can see how this would work and it's an interesting way around the problem.
I can't be absolutely sure yet but I think I've solved the problem (at least using 3750 switches) - you can see outline of how on my last post.   I'm going to give this config a go on our 6500 infrastructure next.. Fingers crossed!
Cheers,
Andy
Rob,
Thanks.  I had some success with something along the lines of what you suggested.  I just used the voice VLANs as the source instead of the interfaces (I did this on a pair of 3750s however so I'm hoping this will work for 6509s)
On switch 01 (where the Voice Recorder is connected on port Gi7/10) the monitoring config I used was is follows:
monitor session 1 source vlan 49 , 51
monitor session 11 destination interface Gi7/10
monitor session 11 source remote vlan 951
On switch 02 (another source where I need to SPAN traffic from) the monitoring config I used here was:
In other words I used local SPANing on the remote switch to monitor the source, and then sent the traffic 'sourced' to the remote destination VLAN 951.
I then used these commands on switch 01.  But switch 01 also had the destination config on it to handle the sending of the traffic on source remote VLAN 951 to the destination interface Gi7/10.
As far as I can tell all calls are recording now for this set up.  I've tested connecting two phones to switch 02 and managed to record the voice stream between the two phones.  In theory the conversation between the two phones connecting to the remote switch (02) should only traverse that switch and not switch 01 so this hopefully means all is good!
Many thanks for your assistance.
Andy
