RSPAN not capturing required data
network_user
I have a RSPAN session configured between a Cisco 3750 and Cisco 2950 switches and I dont see the traffic I am expecting to see on the destination port. I only see broadcast traffic .. HRSP hellos etc. Below is what I have configured on both switches. What is not correct here?
3750 (gi1/0/33)----TRUNK------(fa0/47)2950(fa0/4)-----windows server
3750
monitor session 1 source interface gi1/0/18
monitor session 1 destination remote vlan 901
3750#sh vlan id 901
VLAN Name                             Status    Ports
901  RSPAN                            active    Gi1/0/33, Gi2/0/34
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
901  enet  100901     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Enabled
Primary Secondary Type              Ports
interface GigabitEthernet1/0/33
switchport trunk allowed vlan 11,20,50,80,102,104-106,108,109,901
switchport mode trunk
speed 100
duplex full
end
2950
monitor session 1 destination interface Fa0/4
monitor session 1 source remote vlan 901
2950#sh vlan id 901
901  RSPAN                            active    Fa0/4, Fa0/47, Fa0/48
Remote SPAN VLAN
Enabled
interface FastEthernet0/47
no ip address
duplex full
speed 100
end
switchport access vlan 901
switchport mode access
no ip address
duplex full
speed 100
end
Thank you.
Giuseppe Larosa
on C2950 that is an older platform you need to configure a reflector port (first generation of remote span)
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/configuration/guide/swspan.html#wp1415189
the refllector port cannot be used for other purposes
Hope to help
Giuseppe
Hello Giuseppe,
My RSPAN VLAN 901 is the RSPAN source on Cisco 2950. And I think I am not supposed to or cannot configure "reflector port" when RSPAN is source. My RSPAN VLAN is destination on Cisco 3750 which does not require a reflector port. So I dont have a way to configure reflector port in my case. Does this make any sense ?
Thank you.
Hello Network user,
you are right the reflector port is not needed in all cases as it is explained in the configuration chapter guide I have linked to my previous post.
I apologize for the misleading information.
The real problem with your configuration is that you have put the destination port in Vlan 901 !!!!
no ip address
duplex full
speed 100
end
This is wrong, the destination port doesn't need to be a member of RSPAN vlan
Hope to help
Giuseppe
