RSPAN session not configuring on a WS-C2960S-48TS-S
Kevin Melton
Level 2
Level 2
I was attempting to configure an RSPAN session from one of my clients access layer switches.  here is what I am getting when i get the error that I receive
tbh7#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
tbh7(config)#monitor session 1 destination remote vlan 25
% Invalid input detected at '^' marker.
tbh7(config)#
The version is
tbh7#sho ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 07-Aug-10 23:21 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
tbh7 uptime is 14 weeks, 2 days, 1 hour, 15 minutes
System restarted at 13:57:28 EST Mon Jul 4 2011
System image file is "flash:/c2960s-universalk9-mz.122-55.SE.bin"
Is the code on this not capable of RSPAN?
Thx
Kevin
Reza Sharifi
Do you have LAN base IOS license installed?
To use RSPAN, the switch must be running the LAN Base image.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_50_se/configuration/guide/swspan.html
Reza Sharifi
Thanks for the quick resonse, Reza!
