Basic 861 interfaces configuration
James G Diroff II
Community Member
Hello and thanks in advance for the help.
I have a Cisco 861 and am trying to configure a very basic LAN setup. I have a lot of experience with an 1841 router and am used to working with subinterfaces and connected the router to a separate switch to separate vlan traffic and what not...
The 861 has 1 WAN port, Fa4, and 4 switchports, Fa0-3.
Now, all I am trying to do is establish a LAN segment with PAT. I have the WAN interface working good. I have a static IP and the default route is set... I can ping addresses on the internet. I also have the vty lines setup with SSH and all is working.
Now the LAN configuration is the part I can't seem to figure out. I tried adding an IP to VLAN 1 and doing an extended ping from the address I assigned to the vlan, no success...
Honestly, I'm not sure how to configure the LAN on this at all. I've taken some unsuccessful configuration guesses, but I thought it would be much more time efficient to have someone explain how to configure an ISR router with an embedded switch. I actually have an 1841 in house that has a 4 port switch connected to an addin slot... that I have never been able to use... I assume because I have the same problem understand how it is supposed to be used.
I have read through the configuration guides for the 860 series.. and wasn't able to find much help. I figure I need either to configure the vlans properly or configure a loopback interface... Thanks for the help!
7 Replies 7
Reza Sharifi
Hi James,
How many vlans are you planning to deploy?
Do you have a switch/hub sitting behind this router?
Cab you post "sh run" and sh ver?
cadet alain
suppose you have a PC in vlan 10 on port f1/0 then the config would be:
int vlan 10
ip address x.x.x.x y.y.y.y
no sh
int f1/1
switchport mode access
switchport access vlan 10
Regards.
Alain.
Thank you for the replies.
My initial idea was to deploy 2 vlans, SERVERS and LAN, with intervlan routing so the networks can communicate. Here is the configuration as it stands right now. This is totally cut down to only the essentials and one vlan. The IOS image appears to be limited to only 2 vlans and since vlan 1 cannot be deleted, I believe that I must use it and then configure a second vlan. This configuration current will not allow an extended ping from the inside address of vlan 1 on the router. A standard ping to the net works.
Edit: I only have a few devices to connect to the network at the moment, so I was going to use the switchports built into the router for switching.
Lab#sho ver
Cisco IOS Software, C860 Software (C860-UNIVERSALK9-M), Version 12.4(20)T5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 08-Mar-10 17:36 by prod_rel_team
ROM: System Bootstrap, Version 12.4(15r)XZ5, RELEASE SOFTWARE (fc1)
Lab uptime is 3 hours, 33 minutes
System returned to ROM by reload
System image file is "flash:c860-universalk9-mz.124-20.T5.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 861 (MPC8300) processor (revision 0x100) with 249856K/12288K bytes of memory.
Processor board ID FTX141482E3
5 FastEthernet interfaces
256K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
License Information for 'c860-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
Lab#sho run
Building configuration...
Current configuration : 1323 bytes
version 12.4
no service pad
hostname Areas_Micros_Lab
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 *****
no aaa new-model
ip source-route
ip cef
no ip domain lookup
ip domain name xxxxx.local
ip name-server 208.67.220.220
ip name-server 208.67.222.222
ip name-server 66.155.216.122
ip name-server 207.59.153.242
username ***** privilege 15 secret 5 *****
archive
log config
  hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 207.x.x.x 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
ip address 10.255.255.254 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 207.x.x.x
no ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet4 overload
access-list 10 permit 10.255.255.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login local
transport input ssh
scheduler max-task-time 5000
end
Lab#
This is what I am trying to do with the pings...
Lab#ping 208.67.222.222
Sending 5, 100-byte ICMP Echos to 208.67.222.222, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/12 ms
Lab#ping
Protocol [ip]:
Target IP address: 208.67.222.222
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.255.255.254
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Packet sent with a source address of 10.255.255.254
Success rate is 0 percent (0/5)
Lab#
How the IOS let you configure this? the wildcard mask is not good it must be 0.0.0.255
do a sh ip int br | exc unna to verify int vlan1 is up/up change the wildcard in the ACL and then try again
if it still doesn't work then do debug ip nat and try again.
By the way for your extended ping you can do : ping 208.67.222.222 source 10.255.255.254
Regards.
Alain.
Hi Alain,
The wildcard mask is 0.0.0.255, which is correct.
As Alain noted, can you try ping 208.67.222.222 source 10.255.255.254 or ping 208.67.222.222 source vlan1
Alain,
Thanks for the tip on the extended ping... much easier.
The ACL was and is configured correctly. I'm not sure what you mean about the wildcard mask... it is 0.0.0.255... both in the configuration, and as listed on your reply.
When I do a sho ip bri, vlan 1 is up/down...
So, given that information, I was able to make it work! I knew the problem/answer was simple...
I didn't have any devices connected to the switchports on the router. Therefore, Vlan1 did not come up... which caused the pings from the inside interface were failing.
Oh man I wish I would have realized that yesterday... Thank you to those that helped!
