rspan
jawwalit
Level 3
Level 3
hi all;
i want to ask if 4006 switch support rspan (remote span ) or not.
For your information its contain sup III and IOS software
6 Replies 6
Amit Singh
Yes, it should support RSPAN. What is the IOS you are running. Please paste the show version from the switch.
-amit singh
smothuku
Level 11
Level 11
Hi ,
It supports RSPAN.If possible can you paste the CatOS and IOS which you are using in 4006 switch.
satish
thanks
please see the following IOS version
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-IS-M), Version 12.1(8a)EW1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 20-Feb-02 18:02 by eaarmas
Image text-base: 0x00000000, data-base: 0x00AA30DC
ROM: 12.1(12r)EW
cs-01-lan uptime is 3 days, 14 hours, 40 minutes
System returned to ROM by reload
System image file is "bootflash:cat4000-is-mz.121-8a.EW1.bin"
cisco WS-C4006 (MPC8245) processor (revision 7) with 262144K bytes of memory.
Processor board ID FOX0708S04A
Last reset from Reload
152 Gigabit Ethernet/IEEE 802.3 interface(s)
467K bytes of non-volatile configuration memory.
can you please give me the version of iOS that support Rspan, and how i check in my switch that it support rspan
thanks
I don't think your IOS supports rspan. From the config doc for your IOS they only talk about span:-
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_guide_chapter09186a00800f0e28.html
It looks like you need 12.1(20)EW as a minimum. The best thing to do is check on software advisor which is a Cisco tool
http://www.cisco.com/en/US/support/tsd_most_requested_tools.html
Jon
thanks,
i checked it on the software advisor bu it give the following nessege:
Remote SPAN (RSPAN) Support for source and destination SPAN ports located on other compatible switches
for your knowledge the 4006 consist supIII engine
thanks
