RSPAN
lalmohammad
Hi All,
I have got a core Switch 6506 uplink in ether channel(gi1/1 and gi1/2). core is connected to the access switch port.
uplink-------Core6506-----------access3750-----------Monitoring server
I want to monitor the VOIP traffice on the different access switch.
Please let me know what are the commands i need to exicute to run the RAPAN in Core and the access switch.
Please helppppppp
Amit Singh
First of all you have to create a vlan which will be only used for carrying the RSPAN traffic.Create a dedicated vlan on both the switches:
Conf t
vlan xx
remote-span
On the source switch i.e 6506 you have to run the following command:
conf t
monitor session 1 source < Define the interfaces or source vlan that you want to monitor>
monitor session 1 destination remote vlan xxx
On you destination switch i.e 3750:
conf t
monitor session 1 source vlan xxx
monitor session 1 destination interface fa X/x -> port connected to the monitoring server.
Please use the link below for more info:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/span.htm
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12235se/scg/swspan.htm
HTH,Please rate if it does.
-amit singh
