RSTP blocking switches beyond 20
Torsha
Hi All,
I have a network where there are 31 switches connected in a loop with RSTP enabled and it works fine. Now when there is a break in the loop say at number 30 such that 1------30 break --- 31. Now I see only 20 switches are talking. Why is that happening, ideally only 31 no switch should be out of network. Is this because of max age etc configurations. Please advise.
8 Replies 8
https://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/19120-122.html
I think you are correct' cisco recommends diameter of 7 here there are 30/31 SW so last SW's dont recieve bpdu in time and assume link down.
You can check by see in each SW what the mac address of root SW
If you see more than two root SW then your SW dont receive bpdu in time
MHM
Hi Thanks for replying.
So you mean that in loop (1-----31--1) since there are two routes
1----15(discarding)16-----1
the sw get the BPDU however when the count is 30 the last sw do not get the BPDU in time?
correct
and as I mention use show spanning tree in last SW
in one stp domain there must be ONE root (per VLAN or for all VLAN)
if you see  two or more then there is issue
MHM
Also is there any limitation on the number of devices connected in daisy chain for RSTP enabled switches?
In my set up switches have max age as 20. I changed it 40 thinking that might be the issue but still only 20 switches communicate in daisy chain once the loop is broken
As I know NO
But let check
Share
Show spanning tree in SW in both side of broken link
Show spanning tree interface (broken link) in both SW
MHM
M02@rt37
Hello @Torsha
Do you you have the STP network diameter configured ?
Best regards
Hi ,
no I have not configured this parameter.
Hello
As M02@rt37 stated the default stp diameter is 7, meaning the root path should not exceed 7 stp devices to reach the edge of the l2 network from the root switch
I would suggest NOT to manually change the stp age timers but to change the stp diameter to accommodate your network, this change will automatically adjust the stp timers.
Kind Regards
Paul
