rstp & rapid-pvst compatibility
We connected 2 no 3750 Switch via Fiber cable, 1 switch is running rstp , another one is running RPVST
Is there any performance problem/Broadcast issue can happen
How to check whether any problem / performace issue  is presently not happening
Br/Subhojit
5 Replies 5
Peter Paluch
If you have interconnected two Catalyst 3750 switches, I do not see how one of them can run only RSTP and the other Rapid-PVST. On Cisco switches, there is only PVST or Rapid-PVST - Catalysts have no option of running a global RSTP for all VLANs.
Can you better explain your issue?
Best regards,
Peter
HI,
Sorry for earlier input.
1 3750 switch is having PVST & another is having RPVST
Pls suggest whether any performance issue can happen/stp loop/delay in STP convergence
Br/Subhojit
Hello Subhojit,
RSTP is able to interoperate with legacy STP protocols. However, it is
important to note that the inherent fast convergence benefits of RSTP
are lost when it interacts with legacy STP.
For details about how both protocols interoperate, please see following
documents:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper0918
6a0080094cfa.shtml#comp802
Haihua
daniel.dib
Level 7
Level 7
You are probably running PVST+ and RVPST+ but that is semantics. Is there a reason why you can't run RPVST+ on both?
The fast convergence of RPVST+ is based on synchronizing the topology. That does not work when mixing versions. The RPVST+ switch should detect that the other switch is running PVST+ by the incoming BPDUs. It would then revert to sending 802.1D BPDUs on that interface and rely on timers instead of synchronization.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
This really makes a lot of sense thanks Daniel
