RTP Header Compression only down to 20 Bytes...
Aileron88
Level 5
Level 5
Hi all,
With RTP Header compression on, what would you expect the header size to be? I am only seeing a reduction from 40 Bytes to 20 Bytes, where I'd expect about 4 Bytes. What could the reasons be for this behaviour?
Also, does header compression work on tunnel interfaces?
Aileron88
Level 5
Level 5
Anyone?
