Running-config on stacked switches (C2960S)
PeterJacobsen
Level 2
Level 2
Hi Guys
My company is beginning to have a lot of sites were we are stacking 3 to 4 C2960S-48 switche.
This is making "show running-config" very very long because of the 4 x 48 interfaces.
I can’t find a CLI command that show me the running-config of a ranges of interfaces.
If I for example would like to see running-config for switch 3 (interfaces 3/0/1-52)
The Show Running-config will show all the interfaces (for the two first swtiche = 104 interfaces), which take a time before I reach to switch 3.
I miss a CLI command like:
show Running-config switch 3, or module 3, or
show running-config interface range x/x/x-x
Anyone know a command that can this?
I’m well aware of the CLI command show running-config interface x/x/x, but this will only show me one interface.
TIA
Peter
Neeraj Arora
Level 8
Level 8
I don't think there is a command to show specific Stack member interfaces but you can try the following command for your requirement: "sh run | be 3/0/1" or "sh run | be Gigabitethernet 3/0/1"
Hi Neeraj
It is actually a very useful command.
Thanx
Leo Laohoo
Here's a useful "filter" other than the "|".
This is on the proviso that you have left the terminal length at default ...
1.  Do a "sh run";
2.  When you hit the "pause" or when the CLI will tell you "--More", hit the "/" and enter, say, "3/0/18".  This will take you to the first instance that has the string "3/0/18".
You can also read this.
