Running Configuration backup through FTP
gopi_b4u2003
can anyone advice How to take the configuration backup from switches through FTP. And which software is used for the same.
Thanks in advance
Gopinath.L
johnbroadway
Here's a useful doc for you:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a008020260d.shtml
I use a free tftp server, sorry to use the name here but its by 3com!
hope that helps
John
Hi John,
Thanks for the info..
Anyone update me which software is used as a FTP server for configuration backup
Gopinath
Gopinath
Up to you really, any standard FTP server will do so just pick your favourite. Linux/Unix systems usually come with an inbuilt FTP server, Windows used to have it with IIS but not so sure now but there are many freeware versions out there that you can google for.
Jon
thanks Jon!!!!
Gopinath
