Running IP services and error when disableing EIGRP Stub
doc.toddmartin
Hi there,
I have A 3560x running 12.2(58)SE2 and jus tupgraded to IP services to allow Enhanced EIGRP as found on feature navigator.
I need to run full EIGRP and disable Stub.
however, when I try to disable it, I get this error:
dist2-3560x(config-router)#do sho license
Index 1 Feature: ipservices
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: 0  minute  0  second
Index 3 Feature: lanbase
        License State: Active, Not in Use
dist2-3560x(config-router)#no eigrp stub connected summary
EIGRP is restricted to stub configurations only on this platform.
I have installed the license and rebooted. by all indications th elicense is installed and should allow for Full EIGRP routing.
What am i missing here?
Todd
Andras Dosztal
Level 3
Level 3
Check this white paper and this thread.
Reza Sharifi
You would need to remove EIGRP completely and redo it.
Sw1(config-router)#no eigrp stub
Sw1(config-router)#exit
Sw1(config)#no router eigrp 1
Sw1(config)#do sh run | b router eigrp
Sw1(config)#
Sw1(config)#router eigrp 1
Sw1(config-router)#
