RV082 - Question for routing
hillioncyril
For a professional project, I need to buy a Dual WAN router.
I thought buying the RV082 router, but I have a question about its operation.
I plan to use two WAN connection load balancing.
By against it is necessary for a VPN connection, the output interface is always the same. Our public IP is hardwired to the remote VPN server.
So I wonder if it is possible to define an interface out for this connection? Keeping the load balancing for other connections as the Internet.
And if so, is there any documentation on this?
Thank you in advance
cadet alain
just configure a static route for the remote VPN subnet pointing out the interface you want to use and 2 default static routes each pointing a different WAN interface.
Alain
paolo bevilacqua
Wrong forum, post in "small business router". You can move your post using the actions panel on the right.
