11-08-2012 01:53 AM - edited 03-07-2019 09:56 AM
Hi Guys,
I am required to set a switchport as it follows and I am not sure it will work.
swi mode access
swi acc vlan 10
swi voice vlan 10
spanning-tree portfast
Will the same VLAN ID work for voice and data ? I am having a Cisco Phone connected.
11-08-2012 05:34 AM
It will work but not a recommended solution. Usually you keep voice and data in separate vlans because you need to apply QOS to voice vlan and not the data vlan.
11-08-2012 07:13 AM
if you have to use the same VLAN, I'd recommend
switchport voice vlan dot1p
at least.
HTH,
Milan
