same VLAN on routed and switched inteface of router
jasonww04
Why is f0/0/2 not working?
interface GigabitEthernet0/0
description LAN
no ip address
ip nat inside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 206
ip address 10.192.28.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.2
ip address 192.168.28.1 255.255.255.0
ip nat inside
interface FastEthernet0/0/2
switchport access vlan 206
cadet alain
delete your subinterface config and create  interface VLAN 206 and give it an ip address in the correct subnet.
Do the same for other VLAN in a different subnet.
Regards.
Alain
delete G0/0.1 and G0/0.2
create int vlan 206 and int vlan 2
put an IP on each int for the correct subnet
Do I have to make G0/0 a trunk?
No you don't need to , all hosts on the access ports will use the vlan interfaces to route.
Don't forget to give ip of correct vlan interface as default-gateway for hosts.
Alain.
