Script config changes on multiple switches
Michel-NL
Community Member
Hi there,
I've some Cisco switches in my network (2950 + 3550 + CSB3020 ). I've telnet access to all of them.
At the moment the management IP address is like 192.168.1.x . Now, I want to change it to 192.168.2.x where only the 1 changes into 2.
Off course I can make a file with the login credentials and a few lines to change the IP. Then I would've to change the IP every time and paste it at every management console.
But I'm very lazy. 😉 Is there a way to script this? With an automatic login to all my switches and something like "where 192.168.1.* replace 192.168.2.*"
Is this possible?
Thx in advance.
cisco_lad2004
Level 10
Level 10
yes it is possible.
google net::telnet::cisco .it will save u a lot of time.
unfortunately I do not have the sort of script u are after yet.
Sam
