SD WAN
star1
Hello All,
i am looking to lean about SD WAN and can anyone guide to where and how i can learn about them please
thank you
3 Accepted Solutions
If your CCO is associated with your company then you will be able to access some good resources available for partners.I would suggest you three things:
1) goto salesconnect.cisco.com , search for black belt for partners, choose Enterprise program and then Engineering. You will find track for pre-sales and deployment. I would recommend to complete pre-sales first as it will give good overview about messaging,positioning, architecture and licensing. After that, you can watch deployment.
2) goto dcloud.cisco.com , search for viptela lab as shown in the attached snapshot. It will give you good hands on experience.
Jaime Saldana Morales
You can try the Cisco Learning Library (https://digital-learning.cisco.com) there is a an excellent collection on videos where you can lear about SD-WAN.
The SD-WAN Mastery Collection
Jaime Saldana
Hi starsulaiman21266,
A good start is the resource page found in https://learn-umbrella.cisco.com/
There is a formal training if i not wrong "ADMUMB – Administering Cisco Umbrella Operations v1.0"
Also in dcloud (dclod.cisco.com) you can find demos and a lab for Umbrella.
Hope this helps!
regards,
Jaime
12 Replies 12
Muhammad Awais Khan
Are you work for a Cisco partner or end user ?
Yes, i do work for Cisco Partner.
Thank you Mohammad,
i will have a look and let you know how i get on.
Jaime Saldana
Thank you Jaime,
That was very helpful.
@Jaime Saldana Morales thank you for sharing!
Hello James,
Thank you for the SD-WAN above link. Is there anyway you can advice for Cisco Umbrella as well please?
Hope this helps!
regards,
Jaime
Thank you James
Well there are some articles I wrote on the Cisco Viptela SDWAN which helps you to understand the technology step by step. I will add many more
Cisco Viptela SDWAN: A complete design for Large Enterprise
https://www.thenetworkdna.com/2020/04/cisco-viptela-sdwan-complete-design-for.html
Multicast and Cisco Viptela SDWAN Solution
https://www.thenetworkdna.com/2020/03/multicast-and-cisco-viptela-sdwan.html
Purpose of TLOC in Cisco Viptela SDWAN
https://www.thenetworkdna.com/2020/03/purpose-of-tloc-in-cisco-viptela-sdwan.html
Control Plane traffic security in Cisco Viptela SDWAN
https://www.thenetworkdna.com/2020/03/control-plane-traffic-security-in-cisco.html
DNS Security over Cisco SDWAN: Cisco SDWAN Integration with Cisco Umbrella
https://www.thenetworkdna.com/2020/03/dns-security-over-cisco-sdwan-cisco.html
Troubleshooting guide for Cisco SDWAN control connections
https://www.thenetworkdna.com/2020/03/troubleshooting-guide-for-cisco-sdwan.html
How to configure IPSEC static route in Cisco Viptela SDWAN
https://www.thenetworkdna.com/2020/03/how-to-configure-ipsec-static-route-in.html
Cisco Viptela SDWAN: OMP Graceful Restart!
https://www.thenetworkdna.com/2020/07/cisco-viptela-sdwan-omp-graceful-restart.html
Cisco Viptela SDWAN with Zero Trust Security Model
https://www.thenetworkdna.com/2020/03/cisco-viptela-sdwan-with-zero-trust.html
Zero touch Provisioning (ZTP) in Cisco Viptela SDWAN
https://www.thenetworkdna.com/2020/03/zero-touch-provisioning-ztp-in-cisco.html
Logic behind Application aware routing- Cisco SDWAN
https://www.thenetworkdna.com/2020/03/logic-behind-application-aware-routing.html
Cisco Viptela SDWAN Control Plane setup with Certificates!
https://www.thenetworkdna.com/2020/03/cisco-viptela-sdwan-control-plane-setup.html
Cisco SDWAN: vManage, vSmart, vBond setup from Scratch and the integrations with each other
https://www.thenetworkdna.com/2020/03/cisco-sdwan-vmanage-vsmart-vbond-setup.html
Cisco Viptela SDWAN Value Proposition
https://www.thenetworkdna.com/2020/02/cisco-viptela-sdwan-value-proposition.html
Cisco Viptela SDWAN: Transit VPC in AWS and DIA- Direct Internet Access
https://www.thenetworkdna.com/2020/07/cisco-viptela-sdwan-transit-vpc-in-aws.html
vBond in Cisco Viptela SDWAN
https://www.thenetworkdna.com/2020/02/vbond-in-cisco-viptela-sdwan.html
Cisco Viptela SDWAN: Troubleshooting commands for Control Plane, OMP and BFD
https://www.thenetworkdna.com/2020/07/cisco-viptela-sdwan-troubleshooting.html
Cisco Viptela SDWAN: Configure vEdge via CLI when attached to vManage Template
https://www.thenetworkdna.com/2020/06/cisco-viptela-sdwan-configure-vedge-via.html
How to upgrade the new image on Cisco Viptela SDWAN Controllers
https://www.thenetworkdna.com/2020/06/how-to-upgrade-new-image-on-cisco.html
Cisco Viptela SDWAN: OMP Best Path Algorithm & Loop Avoidance
https://www.thenetworkdna.com/2020/07/cisco-viptela-sdwan-omp-best-path.html
SD-WAN Players: Cisco Viptela Vs VMWare Velocloud Vs Silver-peak
https://www.thenetworkdna.com/2020/07/sd-wan-players-cisco-viptela-vs-vmware.html
Secure Segmentation in Cisco Viptela SDWAN
https://www.thenetworkdna.com/2020/03/secure-segmentation-in-cisco-viptela.html
Fabric Operation in Cisco Viptela SDWAN
https://www.thenetworkdna.com/2020/03/fabric-operation-in-cisco-viptela-sdwan.html
Cisco Viptela SDWAN Licenses and propositions
https://www.thenetworkdna.com/2020/07/cisco-viptela-sdwan-licenses-and.html
inderdeeps
Level 4
Level 4
  1. Cisco Viptela SDWAN: A complete design for Large Enterprise
    1. Multicast and Cisco Viptela SDWAN Solution
    2. Purpose of TLOC in Cisco Viptela SDWAN
    3. Control Plane traffic security in Cisco Viptela SDWAN
    4. DNS Security over Cisco SDWAN: Cisco SDWAN Integration with Cisco Umbrella
    5. Troubleshooting guide for Cisco SDWAN control connections
    6. How to configure IPSEC static route in Cisco Viptela SDWAN
    7. Cisco Viptela SDWAN: OMP Graceful Restart!
    1. Cisco Viptela SDWAN with Zero Trust Security Model
    2. Zero touch Provisioning (ZTP) in Cisco Viptela SDWAN
    3. Logic behind Application aware routing- Cisco SDWAN
    4. Cisco Viptela SDWAN Control Plane setup with Certificates!
    5. Cisco SDWAN: vManage, vSmart, vBond setup from Scratch and the integrations with each other
    6. Cisco Viptela SDWAN Value Proposition
    7. Cisco Viptela SDWAN: Transit VPC in AWS and DIA- Direct Internet Access
    1. vBond in Cisco Viptela SDWAN
    2. Cisco Viptela SDWAN: Troubleshooting commands for Control Plane, OMP and BFD
    3. Cisco Viptela SDWAN: Configure vEdge via CLI when attached to vManage Template
    4. How to upgrade the new image on Cisco Viptela SDWAN Controllers
    5. Cisco Viptela SDWAN: OMP Best Path Algorithm & Loop Avoidance
    1. SD-WAN Players: Cisco Viptela Vs VMWare Velocloud Vs Silver-peak
    1. Secure Segmentation in Cisco Viptela SDWAN
    1. Fabric Operation in Cisco Viptela SDWAN
    1. Cisco Viptela SDWAN Licenses and propositions
