SDM for IPV6
soumik.mondal
Dear All
As per our management policy we have to migrate our data centre to IPV6.Right now each device is running on IPV4.We have catalyst 2960 which I want to configure in dual stack.Now from Cisco site I found that first I have to change SDM into dual-ipv4-and-ipv6.Can anybody tell me what is sdm for switch.Will  this process cause any perfomane and configuration issue in the switch.I am also sending the sh ver .
Can  anybody can send me any docs regarding migration of IPV4b to IPV6 also....
SW-01#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(53)SE2, REL                                             EASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 21-Apr-10 05:52 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01500000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE6, RELEASE SOFTWARE                                              (fc1)
TSDC-EXT-SW-01 uptime is 43 weeks, 6 days, 7 hours, 7 minutes
System restarted at 10:33:11 IST Sat Nov 13 2010
System image file is "flash:c2960-lanbasek9-mz.122-53.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960G-48TC-L (PowerPC405) processor (revision F0) with 65536K bytes of memory.
Processor board ID FOC1404V0A5
Last reset from power-on
1 Virtual Ethernet interface
48 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       :
Motherboard assembly number     :
Power supply part number        :
Motherboard serial number       :
Power supply serial number      :
Model revision number           : F0
Motherboard revision number     : A0
Model number                    :
System serial number            :
Top Assembly Part Number        :
Top Assembly Revision Number    : C0
Version ID                      : V04
CLEI Code Number                :
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 48    WS-C2960G-48TC-L   12.2(53)SE2           C2960-LANBASEK9-M
Configuration register is 0xF
Reza Sharifi
SDM template will assign resource to spesific protocol.  If you enable it, you also need to reload the switch in order for it to take effect.
Have a look at the command reference guide for the 2960 series:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_53_se/command/reference/cli2.html#wp11021317
Also the Configuration Guide would be a good introduction to the issues of SDM:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_53_se/configuration/guide/swsdm.html
Best regards,
Peter
