SDM
alsayed
Level 7
Level 7
HELLO
I Am Unable To Loading Cisco SDM Although I'Ve Enabled:
ip http server
ip http secure-server
ip http Authentication Local
username a priv 15 pass cisco
Also the aaa new-model
And Last JAVA Run Time Being Installed & Enabled on My PC where the SDM Soft Resides,
Could You Please examine the Attachment?I Have a Doubt,might the Problem
is From JAVA!
Plz Examine the down of the sdm PItcture were mentioned: NO SUCH CHILD:0
_________________
THANKS
6 Replies 6
garytayl
Level 7
Level 7
This sounds like a Java issue. If you are running SDM 2.5 and Java greater than 6 update 3 I strongly suggest you to go back to that Java version to make it work. If you require to use an updated version of Java then you should use CCP (Cisco Configuratin Professional):
http://www.cisco.com/go/ccp
Hope it helps....
garytayl
Level 7
Level 7
Hope it helps....
Correct you want to stick to the Java version on the release notes, else SDM will not be working with the newer releases.
If you have to use newer java for security purposes, then you may want to consider upgrading to CCP, the next generation of SDM
I installed JRE 6. updates 3,7,10,13 and 14.
SDM only works with JRE_6.3 and the last one 6.14
siemenseg
Community Member
I faced the same problem it was Java Issue try to remove your current Java and download Java version 5
I faced also this problem.
Version 6 Update 13 was running on my pc. After an upgrade to Update 14 it was working
