05-20-2019 04:12 AM - edited 05-20-2019 07:13 AM
I have a requirement to perform a supervisor upgrade for a client. The setup is as following:
2x 6509 switches with 2 active-standby SUP 720-3B supervisors.
My client initally stated that the switches were acting as a primary/secondary HSRP pair, but apparently it is not enrirely the case. This means that although HSRP is configured for a lot of their SVIs, some servers are only physically patched to one of the 2 switches.
Presales have scoped 4x VS-S2T-10G cards to perform a seamless upgrade on the secondary unit first and then the primary. The full BoM is as below:
VS-S2T-10G= Cat 6500 Sup 2T with 2x 10GbE and 3x1GbE with MSFC5 PFC4
S2TIBK9-15201SY IOS IP Base
MEM-C6k-INTFL 1GB Internal 1GB Compact Flash
VS-SUP2T-10G Catalyst 6500 Supervisor Engine 2T Baseboard
VS-F6K-PFC4 Cat 6k 80G Sys Daughter Board Sup2T PFC4
MEM-SUP2T-2GB Catalyst 6500 2GB Memory for Sup2T and Sup2TXL
The current switches have the same setup as per below:
MUK_Core1#sh module
Mod Ports Card Type Model Serial No.
1 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE
2 24 CEF720 24 port 1000mb SFP WS-X6724-SFP
3 8 Network Analysis Module WS-SVC-NAM-2
4 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B
6 2 Supervisor Engine 720 (Hot) WS-SUP720-3B
7 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX
8 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX
9 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX
My questions are as following:
1) Is it possible to perform a seamless upgrade between on the switches?
I will need to remove the SUP 720-3B hot standby, install the VS-S2T-10G, save the config (and hopefully VLAN.dat) and force a failover.Do some verification tests and also do the same on the (previously active) card.
2) Is there an official guide on how to perform a seamless hardware upgrade on those devices? I could only found an upgrade guide for IOS images but no guide into actually upgrading a supervisor while the chassis is running.
Edit: I have clarified some things and added more information.
Solved! Go to Solution.
05-20-2019 08:19 AM
I understand your concerns.
Normal linecards support online insertion and removal and so you could extract one and then do all necessary operations on it like changing the DFC as I have explained before.
However, when it comes to supervisors you can remove the standby supervisor and insert the new one, but I am afraid that the system can be unstable or even it can crashes with two supervisors with different models and generation.
Notice also that each supervisor either Sup720 and Sup 2T has also on board its own switching fabric and they have different speeds.
The only tuning that might help is reviewing the redundancy mode:
stateful switchover SSO requires supervisor models to match for sure.
A possible approach could be that of changing redudancy mode from SSO (likely configured) to RPR that has looser requirements.
However, my guess is that new Sup 2T will stuck in ROMMON state until the first Sup720 is present and active.
Besides this linecards, with new DFC4 will likely be put offline by Sup720 if it finds out a non matching DFC on the linecard.
If all linecards have CFC is easier for the linecards as they do not need any change.
Plan a very long time window for maintenance.
Have all HSRP groups active on chassis1. Disable all access switch links to chassis2 for safety.
And make the migration on chassis2.
From lessions learned on this first migration you will know how long it takes to perform the process.
In the third migration phase you can build the VSS between the two chassis with all new Sup 2T installed and running.
Hope to help
Giuseppe
05-20-2019 04:29 AM
Hello jtenteprise,
first of all, SUP 720 3B does not support VSS, or the current setup is not using a VSS, or the current supervisors are of different type that supports VSS.
Second point: in order to properly support linecards with DFC, you would need to buy and install DFC4 for them.
See the following datasheet for VS-2T-10G
If you have linecards using DFC, there is no way to perform a seamless migration as you need to power off the chassis, extract each linecard and change every DFC daughther card with DFC4 new one.
Hope to help
Giuseppe
05-20-2019 07:51 AM
The switches are only running HSRP between them and No VSS.
What I was asking is whether I could perform a line card upgrade without powering the entire switch off. I cannot seem to find any documentation whether this is possible or not.
Each switch has 10 years of uptime. I am too scared to power them off, unplug the old sups and install the new ones. I am pretty sure it will never come back up.
Is a sup upgrade even feasible or do I need a complete outage?
05-20-2019 08:19 AM
Hope to help
Giuseppe
05-20-2019 08:32 AM
Wow,
This was the most detailed explanation I got regarding a sup upgrade!
Thanks.
And by the way, I forgot to post the daughtercard output of the switch. You were right, we do need to install new daughtercards.
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC 2.1 Ok
2 Distributed Forwarding Card WS-F6700-DFC3B 4.6 Ok
4 Centralized Forwarding Card WS-F6700-CFC 4.1 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B 2.3 Ok
5 MSFC3 Daughterboard WS-SUP720 3.1 Ok
6 Policy Feature Card 3 WS-F6K-PFC3B 2.3 Ok
6 MSFC3 Daughterboard WS-SUP720 3.1 Ok
7 Centralized Forwarding Card WS-F6700-CFC 4.0 Ok
8 Centralized Forwarding Card WS-F6700-CFC 4.0 Ok
9 Centralized Forwarding Card WS-F6700-CFC 4.0 Ok
05-20-2019 08:20 AM
05-20-2019 04:33 AM
