Security Features of 3560-x with IOS 15.2(2)E
antoniobelli
Hi All,
I would like to know for sure if the following features are included in the switch 3560-X
  • Threat Defense : Port Security, DHCP Snooping, Dynamic ARP Inspection,IP source guard.
  • Advanced Security Features : Secure Shell (SSH) Protocol,Switched Port Analyzer, RADIUS authentication, ecc.
These are the informations about my software and release
SoftwareIOS
Release Number15.2(2)E
Platform NameCAT3560X
Feature Set/Supervisor(NX-OS specific)UNIVERSAL (IP BASE)
SoftwareIOS
Many thanks for your answers
Antonio
Hi Antonio,
I took a look at the config guide below and all are supported.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-2_2_e/configuration/guide/b_1522e_consolidated_3750x_3560X_cg.html
Hope this helps.
PS : Kindly rate all posts which are helpful
Madhu.
Hi Antonio,
Hope this helps.
Madhu.
Thanks Madhu,
It's sure that there are included also in IP Base IOS? Or do I need IP Services IOS?
Leo Laohoo
I personally do not recommend any sane person to use 15.X on a Catalyst 3560X/3750X due to known stability issues.
Look at using 12.2(55)SE10.  The features you seek is also found in this level.
