Security Pros and Cons with enable SNMP
reginaldjohnson
I have several Cisco devices and I recently purchased Solarwinds NPM. This software requires that SNMP be enable in order to mointor network devices and traffic.
Questions: if the snmp is enabled is enalbed on my Cisco equiptment is there any secuirty flaws that could give remote users access or infomations that could casues a security breach.
2 Accepted Solutions
stephenshaw
Also, a couple of more items .... don't use the default community strings of "public" and "private." Plus implement an ACL on each network device that will limit SNMP access for the specific IP address of the Solarwinds server.
Ganesh Hariharan
The best way is to have a standard community string configured between the devices and server with version 3 selected which is encrypted also to have high level of security and with cisco switches you can also have acl with sepecifc server can poll the switch with configured read only community string.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
The recommendation is to use SNMPv3 since it encrypts the traffic and requires authentication.
It provides greater security enhancements compared to the previous versions which provide little to no security at all.
Federico.
stephenshaw
Ganesh Hariharan
Hope to Help !!
Ganesh.H
reginaldjohnson
Thanks. The info you guys provided was a big help.
