send multipla vlan data
Manish Manwal
Level 4
Level 4
hello all;
we create three vlan in our network and then do intervlan routing through multilayer switch.
i want to communicate these vlan from other network.we can ping sub interface of router, but cant not ping default gatway, that are configured in L3 switch. we ping form 172.16.16.2.
where is the problem
THANKS
MANISH MANWAL
khldk
Please print output of:
show ip int bri
show ip route
On the routers and switches.
output of router and switch
THANKS
MANISH MANWAL
You are missing router 1 and the multilayer switch.
From this output I can see that replies would go from router 0 to router 1, if the traffic is going all the go there.
sir
routerr 1 is working properly
the switch configuration is also send on this attachement
THANKS
MANISH MANWAL
