separate traffic
trombidz1
Level 2
Level 2
Hi ,
I would like to configure a router to route two different traffic ( one for DMZ 192.168.60.0 and one for DMZ 192.168.61.0 ) Actually the router is already routing traffic to 192.168.60.0 and I need to modifiy the config for .61.0
I found this article :
http://www.cisco.com/warp/public/473/171.html
If you have a look to the diagramm, this is what I need to do .In my case it will be DBZ instead of PC . How can I setup the router to route traffic to both DMZ ?
can that work ?
Do I have to setup a trunk to pass traffic for both dmz ? something like 1 sub-interface for 192.168.61.0 and one for 192.168.61.0 ? encapsulation
many thanks for your help
You certainly need to configure the link between the router and the switch as a trunk.
On the router, You will indeed have to configure one subinterface for each DMZ.
I would recommended dot1q for the encapsulation, as ISL is probably not supported anymore on most equipment.
Hope this helps,
